is it possible? has ne1 done it?
northstar z-34
I think you'd run into some major clearance issues, both lengthwise and widthwise. So, if you want to cut your car down the middle to widen it up, and extend the front to give more engine room.... Picture a 3.4 with an extra 6+" for those extra 2 cylinders
Oh - but - I believe the 4.9 has been shoehorned into some form of W body... I forget which at the moment though.Okay now, that's enough of that.
A 3.4DOHC is a big engine height wise. The Northstar shouldn't be much taller at all. As far as width goes, it won't be much wider either. Northstars are pretty compact and I've heard that they are almost the same size length wise as some V6s... so the 6" extra for that extra cylinder probably won't apply.
And like was mentioned... ASG has put a Caddy V8 in there, so the N* should fit with no problems.
On another note, I've seen an N* in an Alero...-Brad-
are you SURE that was a northstar in an Alero, and not a Intrigue? I know Olds had a prototype Intrigue with the Northstar, and a prototype Alero with the 3.5DOHC
Oh, and the small-block chevy V8 is smaller than the northstar. (that's why the CTS-V doesn't have the northstar, it was too big)
Cliff Scott
89 BerettaGT
89 Volvo740Cliff Scott
89 BerettaGT
04 AleroGX
screw the northstar then. a lumina z-57, cammin like a big dog and then i wake up.The Official Rotating Mass Nazi
It wasn't a concept. It was someone who took the time and spent the $$ to put it in. I remember seeing pics of it on GAGT awhile back.-Brad-
now I have seen somewhere the SBC swap.... I beleive it was a 4.8l truck motor put in an Impala.... which shares its GenIII design with these motors: 4.8, 5.3, 5.7, and possibly the 6.0. I can't remember if they changed the block on the 6.0's or not in the new trucks....1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
1962 Buick Electra 225 STOCK... and gonna keep it that way
I inquired about this topic around 6 months ago, and got shot down. Somebody on this forum measured the NorthStar and said the width and height was too much, partially due to the tranny attached to it and said the only way to get it in, would be chopping up the frame .. Just letting you know of what I heard, and by no means trying to discourage you ..
I would definately attempt it if I knew a 5spd would mate to it, cause I highly doubt my GETRAG 284 would just bolt right to it .. Good Luck ..
