Whats up all, I have a slightly modded 3.1 MPFI and I have been looking for a bit more power. I found a 3400 top end everything I need for 150 snaps! but its 2hrs away, anyways I need to know what sized pushrods to use, I will be taking the heads to a machine shop for the works and also using rocker rollers and better valve springs also is it worth it to get a copper head gasket (if you can) the car might see boost down the road. Should I use the 3.1 stock injectors or the 3.4.
Thanks
Thanks
