60 degree v6?
  • 60 degree v6?
    Is the 3.6 vvt or the 3900 a 60 degree engine and if so will these engines bolt up to a 4t60-e?
    Yes, and yes. Im not sure how long a 4T60-E will last with them or how you will control the VVT and a 4T60-E on the same ECM.
      the 4t60e will last a long time. just be sure to install an adjustable modulator and firm up the shifts, but not too much as at close to max line pressure, you'll damage the pump.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
