I'm sure this is a common question, but I did do a couple searches and didn't find the info I needed. I need to know which front accessory drive I need to use. It's a 3.1 from a '91 Cavalier. If I spin the induction around it interferes with the water pump (and probably more) of the Cavalier setup. I want to use a serpentine setup like the Cav had (I'm so sick of V-belts!!) and I'd like to keep the Cav plenum.
Any suggestions are appreciated. I plan on no A/C or power steering and I can modify/fab up pieces if I need to. Also this is going into a Chevette so it can't be too wide at the bottom of the engine.
Thanks,
Phill
Thanks,
Phill
