Top-end swap checklist?
  • Top-end swap checklist?
    As in another post I'm looking at doing my LIM gaskets 'cause they are leaking pretty bad now and figured I might as well put an 00+/LG8 top end on my older (1997-year) L82 3100...
    So I'm still trying to gather the parts--UIM, LIM, TB and heads, but in the meantime I'm also getting the gaskets and other stuff I'll need for the repair/swap...
    Right now I've got the following already...
    -Fel-Pro MS98003T (LG8/LA1 application) Perma-Dry Plus intake manifold set (has UIM/LIM gaskets, valve cover gaskets, stat seal, black RTV)
    -Fel-Pro ES74017 Head Bolt set
    -Fel-Pro 9957PT PermaTorque Head Gasket (x2)
    I'm guessing I'll also need the following other parts as well?:
    -EGR Gasket
    -Throttle Body Gasket
    -Exhaust Manifold Gaskets
    -Torque Wrench (have a bigger one but not a lower-torque one that's required)
    -Torque Angle Meter
    -Serpentine Belt remover tool
    -High-Temp threadlocker for the intake bolts
    -new injector and fuel connection o-rings
    Other things to have done:
    -tap the coolant connection on the LIM as it's threaded on my car and a press fit or something on newer cars IIRC.
    Is there anything I'm missing or anything I don't need on that list? Should I get new intake bolts as well?
    Also I noticed Fel-Pro also has "Severe Duty" head gaskets, part number 511SD but they are special order. Are these worth getting (I could return the other ones, no problem) or should I just stick with the regular ones I bought? Or should I buy GM ones (does GM/Delco have their own because I didn't really find them anywhere though I didn't try that hard, lol). Also same question on the head bolts, should I buy GM ones instead?
    Anyway sorry I'm being a noob, it's the first time I'm doing this myself... Thanks for any advice you guys could give!
