I just wanted to know if 3400 heads will go on a 3.1MPFI. If they will what else has to be swaped, obviuosly the intake manifold but what else. anyone know?
will 3400 heads go on a 3.1?
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mileTags: None
