Originally posted by SHOoff
It is all ready set up to run with the stock GM MAP. You can even run both MAPS so that it is constantly adjusting to the altitude, like if you were to drive it up a canyon (pikes peak).
I think the stock MS MAP is better than the GM one and can read up to 2.5 bars and for $30 more dollars you can upgrade to the 3 bar (thats 30 lbs of BOOST).
