Connector
  • Connector
    Anyone know where I could buy a connector that takes the place of the ECM, and just "breaks out" the wires(to visualize: instead of an ECM u have wires so that I can connect my own ECM, but dont cut off the connector)? I dont want to slice 'n' dice my engine wiring harness, so I can rollback in seconds if needed.
    Thanks for all the help
    Oh yea, its a 96' grand am with 3.1/X hybrid
    Automatic.
      What ECM are you putting in it's place? You'll need one that does the trans control...
      If/when I go to megasquirt, I plan to take a spare ECM, and hack it up... so that it still controls the trans, but also it has wires going to the megasquirt.
      So I'll disconnect the connector traces on the ECM and solder on wires coming off of that to the MS box...
      So thats what you could do ... grab another ECM, and take it apart and unsolder the connector off the PCB, then solder your wires to the pins on the connector and run that to whatever. So you just are stealing the connector off the ECM....
      Check www.eficonnection.com too they may have something.
        Read through this : http://60degreev6.com/Articles/Misc/...ade%20Swap.doc
          good to see you're finally making use of it...
            Stupid question alert: Are OBD 1 connectors the same as the ones used for OBD 1.5? If so that would have saved me a huge amount of trouble with my megasquirt install so far. I thought of using an identical PCM for that purpose but the connector was integral with the PCM's housing.
            1995 Grand Am SE
              why are you talking about obd1.5, you have a 96, right? thats obd2. and i think the only obd1.5 vehicles that got a obd2 connector were the LT1s(vette/camaro/bird/impala/roadmaster). maybe the lesser models got them too but those are definitley obd1.5 with obd2 connectors
                Is OBD1 94/95? or 96/97? My wiring diagrams show a huge differance between 95 to 96.
                  For now, im interested in just getting into the stock oem programming, to just learn and possibly remove the speed limiter.
                  When more money comes my way I plan on buying something like the MegaSquirt, which is very attractive in terms of money and pride of craftsmanship hehe.
                  Then later on when I have the MS down pat, I plan on trashing the stock intake and exhaust for a turbo system, prolly just a mild 5-10 psi setup, the car is actually my wife's and I dont want something with tooo much bang lol.
                  But I do want to exercise extra controls and how they influence the motor for later use, like oil squirters and extra fuel injectors, for later applications on other vehicles.
                    Can MS control a Tranny, eventually? They say nothing about doin that on the site. Just wondering.
                      heres the simple version:
                      obd1: everything up to and including 93. after that very few vehicles(mostly trucks) still used that system
                      obd1.5: almost everything 94-95.
                      obd2: 96-up everything
                      make sense?
                        i cant help you with anything obd2 since i've never had to deal with it.
                        the MS "team" of bowling and grippo(?) are working on a LOT of enhancements and i believe tranny control was one of them, but as of yet i don't think its been done. the thing to do in that situation is to use the factory PCM to control the tranny and the MS to control everything else
                          Sorry for complicating the thread a little.
                          The megasquirt guys were working on a GPIO (general purpose input output) expansion board that could control an automatic transmission among other things. The testbed for it is a 4L60E so most of it might directly apply to 4T60E's.
                          1995 Grand Am SE
                            yep, that would be it... MS is slowly becoming a full PCM...
                              MS3 is in the works!
                              95 Beretta- Lg8 Daily Driver
