setting megasquirt timming offset
  • setting megasquirt timming offset
    I have a msII v3 running a '03 3400 with dis in a fiero, I want to set the timing offset. I borowed a cheap timing light but I can't find the timing marks on the damper. I don't know that much about setting the timing, so if you could give me some pointers I would really apreciate it. should I get a digital timing light? any recomendations on brand/model?
    Thanks
    '86 fiero-'03 3400 running on megasquirt II v3.
    Because that motor came with dis they dont put timing marks on the pully anymore...
    EFI, Fuel Injection, Auto, automotive, car, TPI, computation, ECU, MegaSquirt, GPIO, MicroSquirt, Sequencer, stim, MegaShift, MShift, DIY, transmission, 4L60E, 4L80E, controller, shifter
    Does that help at all?
    If not, you could use an external trigger that WOTtech sells. That way you can manually offset the timing. But im sure theres an easier way... I havent started tuning yet.
    95 Beretta- Lg8 Daily Driver
      Most tuning files I see for the 3x00's have a 57 degree offset. I'd wait and see if someone else can confirm that though.
      1995 Grand Am SE
        My MS setting for my 3400 in a 93 cavy
        1993 Chevrolet Cavalier Z24
        3400 Turbocharged Intercooled
        MS3 v3.57+MS3X
          57 to 60 degrees. Same as when we us a V8 mask on a DIS vehicle with OBD1
