gm crate 3.4l to tbi
  • gm crate 3.4l to tbi
    just wondering if anyone knows if theirs a after market tbi setup that will work with this motor and I'm planning on a turbo
    thanks jamey
    that link would be something you need to do inorder to use a turbo on a TBI system. If you can find a 454 TBI buy it it has 2" butterflies on it. Would be more condusive to the Turbo. you would have to buy a hat like that guy did. I know it says supercharging but its the same style of blow threw.
    Holley sells I believe the 454 TBI and the 4.3 tbi(I bought that) as well but you would have to swap out the injectors. if you read the most of the links that that guy provides on his page its going to be alot of the same work. I can't help to much in the how too. All that work should be the same he was just using a powerdyne superchager(belt driving Turbo.)So alot of the things he does will apply to the application your trying to build. Hope that helps There is alot of good reading there.
    Also your not going to get to much traffic on this thred here you should email one of the moderators and see if they couldn't move it for you. It would go under performance pushrod or boost sections. You will find more far more responce there.
      If you are turboing then you should switch to Port injection. It is a far superior system. The conversion is rather simple if you use Camaro EFI parts. It can be done with TBI but Port Injection is easier and more reliable when boosting.
