Does anyone know where to buy and how much money it is for a OBD2 connector to a serial port for a laptop? Also what about the GM connector to laptop cable?
OBD2 to Laptop Cable
Carplugs OBD2
Hi guys,
Here is a better place for obd2 cables and connectors:
http://www.carplugs.com/
Obd2 cables
Intravino
Obd2 cables
Intravino
i'll have to look into one for my '04 grand am.
is there any cross referance as to which plug to use for which car?
Cable
is there any cross reference as to which plug to use for which car?
http://www.carplugs.com/obd2scantool.html
It comes with the obd2 cable, interface and the serial cable.
It is available also in USB output instead of RS232(serial).
obd-2.com has the interface inside the cable.
If you have already an interface, I recommend this cable:
http://www.carplugs.com/Product_view_Cables_3.html
Thanks,
intravino
Originally posted by Impetuousracer View PostI went with this guy: ($83 Includes Free Software, works on any OBDII)
The I used this Serial to USB connector to work on Vista 64 ($20)
http://www.usbgear.com/computer_cabl...6%2C1009%2C601
FYI, all GM vehicles starting in 06 changed over to the CAN protocol with most of the 60* V6 powered vehicles changing in 05. The traditional OBDII scanners cannot read this protocol.Your local OBDII moderator
2000 Grand Am GT w/ WOT parts
