99' grand am key on no SES light w/lx9 f23 swap
  • 99' grand am key on no SES light w/lx9 f23 swap
    Issues resolved, mixture of cleaning all grounds unplugged PCM and all connections on the vehicle and we were all good to go!
    Hello everyone here I'm working on my lx9 f23 swapped grand am and now I've hit an issue. It starts then dies, no security lights, but key on car off there is no SES light lit up. I know that the SES light has always lit up before today. Yesterday I had been messing with the clutch pedal and pushrod all morning, is there something I may have bumped? I read that pcm connector c2 pin 24 is the ignition 2 pink wire that needs 12v to light the SES light and allow the engine to run.
    Cluster has been tested and all lights work in a second grand am
    -key on car off No lighting of the SES light during bulb check
    -Gauge cluster doesn't light again after the first key cycle until you unplug and replug the cluster.
    -just can't believe after all this work, something like this is stopping me from test driving the car.
    what PCM are you running? I had the same problem with my LX9 F23 fiero swap, I was missing a 12v+ pin.
