expanding tuning capabilities?
  • #61
    I took a hiatus myself. Upgrade training, studying the PDG, sq SME, now instructor training!
    Here's some links to stuff I was studying...
    Bytes and bits are the starting point of the computer world. Find out about the Base-2 system, 8-bit bytes, the ASCII character set, byte prefixes and binary math.
    Would you like to be able to build your own digital devices? Logic gates are the basis of digital electronics. Find out what these gates do and how you can use them to start building your own devices.
    When I left off earlier this year I was at the point where I could sorta understand certain parts of the code, but had no idea where to implement it. Its a PITA when you don't know exactly where to start, I was hoping to see one of the resident programmers build a small tutorial on how to add a patch or something. A good tool to invest in is a test bench, build one with the help of the pros so you can experiment with code without worrying about blowing up your car. Im hoping to build one in the near future, but looks like ill get PCS'd within the year so Im already starting to pack up some non-essential crap in the garage lol. Good Luck!
    thanks for the links, the 3rd one has lots of cool info. a good starter for someone who doesn't have a clue like me.
    • #62
      more useful info:
      Edit: more
      • #63
        alright, got a jimstim, got it assembled, now it's time to start playing around a bit, anyone got a PCM they want to send me? :P
        • #64
          !! I think I finally found the spark table headers, I'm starting to figure a thing or two out here slowly...!
          edit: maybe not, but still learning a thing or two.
          • #65
            ok, I've been kinda trudging my way through this, and I'm really not making the headway I would like. a big problem for me, is that I don't have a knowledge base in coding, right now, I'm just kinda blindly fighting through and looking at each command one at a time. I've found a couple of tricks, like changing the settings so IDA doesn't abbreviate the commands down as much. I really need something that's a little less of a crash coarse so I can have a better understanding of what I'm looking at. does anyone have any suggestions? I'm all ears.
            • #66
              I figured this might be helpful for me, so it might be helpful for others too, parameter addresses for the short* bin osid 12586835 all addresses are according to tiny tuners database. I think some might be wrong though, still looking into it.
              1c970-ect temp vs votage
              6f1d8-ignore flash checksum
              6f1d9-disable flash security
              6f1da-module programmed
              6f1dc-engine type
              6f1dd-crank resolution
              6f1de-supercharger present
              6f1e8-a/c RPM disable
              6f1f4-a/c on startup delay
              6f208-a/c min air temp
              6f20a-a/c disable/re-enable ECT
              6f20e-a/c disable/re-enable tps
              6f212-a/c disable timer
              6f22a-a/c disable/re-enable ignition voltage
              6f234-MAF airflow table
              6f2d6-MAF max positive airflow change
              6f2fc-MAF negative airflow change
              6f398-transient airmass calc mode
              6f39a-max cylinder air mass
              6f3a0-transient airmass calce enable positive tps delta
              6f3a2-transient airmass calc enable negative tps delta
              6f3aa-default mass airflow (GM/sec) vs TPS vs RPM
              6f674-MAF failure airmass calc mode
              6f68a-speed density maf compensation vs ect
              6f69e-speed density maf compensation vs baro
              6f736-volumetric efficiency
              6f934-ve correction vs tps vs egr state
              6f94c-speed density maf compensation vs IAT
              6fae0-air pump system present
              6faf6-air pump enable startup coolant temp
              6fb2c-alternator startup delay vs ECT
              6fb40-alternator RPM cutout
              6fbea-default baro
              6fbec-always use default baro
              6fbf0-SC baro lookup
              6fc32-NA baro lookup vs tps vs rpm
              6fe4e-o2 sensor config for pid 13
              6fe50-boost delay-boost timer base
              6fe66-boost delay-timer adder tcs on
              6feaa-boost delay-timer adder tcs off
              6fefe-CCP enable coolant temp
              70060-ect ok enable ert
              70062-ect ok enable ect
              70064-ect ok disable ect
              70066-ect ok enable ect dtc set
              70068-ect ok disable ect dtc set
              7006a-ect temp vs ert
              702d6-knock sensor diagnostic min ect
              702d8-knock sensor diagnostic min engine load
              702da-knock sensor diagnostic rpm thresholds
              702e8-knock sensor diagnostic min ert
              702ec-knock sensor circuit diagnostic min fails per sample to set DTC
              702ee-knock sensor circuit diagnostic test sample size
              702f0-knock sensor diagnostic min fails per sample to set DTC
              702f2-knock sensor diagnostic test sample size
              702f4-knock sensor diagnostic max KR
              702f6-knock sensor diagnostic min tps
              702f8-knock sensor diagnostic min ign volts
              714e4-flash checksum
              71502-CAT diagnostic tests per trip
              71503-CAT diagnostic tests count to pass
              71504-CAT diagnostic tests count to fail
              7150a-idle diagonostic min tests to set dtc
              71512-max idle rpm variance vs ect
              71596-crank and cam sensor circuit diaognosic min ERT
              71598-p0341 min fails per sample to set dtc
              7159a-p0341 test sample size
              7159c-p0336 min fails per sample to set dtc
              7159e-p0336 test sample size
              715a0-p1374 min fails per sample to set dtc
              715a2-p1374 test sample size
              71638-max MAF frequency
              7163e-min maf frequency
              71644-maximum delta airflow
              7165a-p0106 max map volts vs tps vs rpm
              716f4-p0106 man map volts vs tps vs rpm
              7178e-p0108 and p1106 min fails per test sample to set dtc
              71790-p0108 and p1106 test sample size
              71792-p1107 min fails per test sample to set dtc.
              71794-p1107 test sample size
              71796-p0106 number of times out of range to set p0106
              7179a-p0108 min fails tper test sample to set DTC
              7179c-p0108 rpm threshold
              7179e-p0108 test sample size
              717a0-p0107 min fails per test sample to set DTC
              717a2-p0107 RPM threshold
              717a4-P0107 test sample size
              717a6-p0108 min map volts
              717a8-P0107 max map volts
              717aa-p0108 max tps above rpm threshold
              717ac-p0107 min tps above rpm threshold
              717ae-p0108 max tps below rpm threshold
              717b0-p0107 max tps below RPM threshold
              717b6-p1112 min mph
              717b8-p0113 min ect
              717ba-p0113 max airmass
              717bc-p0113 max mpH
              717be-p0113 min ert
              717c2-p1112 min ert
              717c7-p0112 min raw IAT count
              717c8-P0113 max raw IAT count
              717ca-p1111 and p1112 test sample size.
              717cc-P0113 min fails per test sample to set dtc
              717ce-p0112 min fails per test sample to set DTC
              717d0-p1111 min fails per test sample to set dtc
              717d2-p1112 min fails per test sample to set dtc
              717d4-p0112 and p0113 test sample size
              717d6-p0030 fail time
              717d8-p0300 IGNV thresholds
              717dc-p0230 fail time
              717de-p0230 ignv thresholds
              717e2-p0403 fail time
              717e4-p0403 ignv thresholds
              717e8-p0654 fail time
              717ea-p0654 ignv thresholds
              717ee-p1689 fail time
              717f0-p1689 ign v thresholds
              71860-p1121 min fails per test sample to set dtc
              71862-p1121 test sample size
              71864-p1122 min fails per test sample to set dtc
              71866-p1122 test sample size
              71868-p0121 min ect
              7186a-p0121 min ert
              7186c-p0121 min fails per test sample to set DTC
              7186e-high TPS diagonostic max map
              71870-low TPS diagnostic min map
              71876-p0121 test sample size
              71878-p0123 min fails per test sample to set dtc
              7187a-p0123 test sample size
              7187c-p0122 min fails per test sample to set dtc
              7187e-p0122 test sample size
              71880-p0123 min tps volts
              71882-p0122 max tps volts
              71884-high TPS diagnostic predicted TPS vs RPM
              718a4-low tps diagnostic predicted TPS vs RPM
              71e16-misfire max delta time-low rpm-cyl mode
              71f48-misfire max delta time-mid rpm-cyl mode
              7209c-misfire max delta time-high rpm-cyl mode
              721ce-misfire max delta time-low rpm-rev mode
              72300-misfire max delta time-mid rpm-rev mode
              72454-misfire max delta time-high rpm-rev mode
              725c8-misfire detection disable coolant temp
              725ca-misfire detection enable coolant temp
              725c5-misfire detection min ect coldstart
              725d0-misfire detection coldstart ECT definition
              725d2-misfire detection high rpm threshold
              725d4-misfire detection low rpm threshold
              725b5-firing order
              72646-p0130 and p0150 min ect
              7264a-p0130 and p0150 min ert
              7264e-p0130 and p0150 rpm thresholds
              72654-p0130 and p0150 airmass thresholds
              7265c-p0130 and p0150 tps thresholds
              72658-p0130 and p0150 ignV thresholds
              7265a-p0130 and p0150 conditions enable time
              72794-p0132 and p0152 min fails per sample to set dtc while in pe
              72796-p0138 min fails per sample to det dtc whlie in pe
              7279a-p0132 and p0152 test sample size while in pe
              7279c-p0138 test sample size while in pe
              727a0-p0132 and p0152 max o2mv in DFCO
              727a1-p0138 max o2 mv in dfco
              727a8-p0131 and p0151 min fails per sample to set dtc
              727aa-p0137 min fails per sample to set dtc
              727c0-p0131 and p0151 test sample size
              727c2-p0137 test sample size
              727c6-p0131 and p0151 max o2 mv
              727c7-p0137 max o2 mv
              727d8-p0134 and p0154 min fails per sample to set dtc
              727da-p0140 min fails per sample to set dtc
              727de-p0134 and p0154 max o2 mv
              727df-p0140 max o2 Mv
              727e2-p0134 and p0154 min o2 mv
              727e3-p0140 min o2 mv
              727e6-p0134 and p0154 test sample size
              727e8-p0140 test sample size
              727ec-p0131 and p0151 min fails per sample to set dtc while in pe
              727ee-p0137 min fails per sample to set dtc while in pe
              727f2-p0131 and p0151 test sample size while in pe
              727f4-p0137 test sample size while in pe
              727f8-p0131 and p0151 max mv while in pe
              727f9-p0137 max Mv while in pe
              72816-p0137 max Mv while in pe
              72818-p0138 min fails per sample to set dtc
              72822-p0132 and p0152 max o2 mv
              72823-p0138 max 02 Mv
              7282e-p0132 and p0152 test sample size
              72830-p0138 test sample size
              72b4a-fuel trim diagonostic minimum baro
              72b4c-fuel trim diagnostic ECT thresholds
              72b52-fuel trim diagnostic airmass thresholds
              72b5a-fuel trim diagnostic minimum fuel level
              72b5c-fuel trim diagnostic MAP KPA thresholds
              72b60-fuel trim diagnostic IAT thresholds
              72b68-fuel trim diagnostic intrusive mode airmass thresholds
              72b70-fuel trim diagnostic intrusive mode min RPM
              72b78-fuel trim diagnostic RPM thresholds
              72b7c-fuel trim diagnostic maximum MPH
              72bb6-idle diagnostic min baro
              72bb8-idle diagnostic min ect
              72bbe-idle diagnostic min IAT
              72bc0-idle diagnostic IGNV thresholds
              72bc8-idle diagnostic max TPS
              72bca-idle diagnostic max MPH
              72bda-p0101 EGR limits
              72bde-p0101 max map
              72be0-p0101 ignV thresholds
              72be6-p0101 max airmass
              72be8-p0101 max delta map
              72bea-p0101 max evap purge percent
              72bec-p0101 criteria enable time
              72bee-p0101 TPS thresholds
              72c1a-dtc fault type
              72d0a-DTC fault enabled
              72eec-egr disable run time vs start run coolant
              72f3c-egr air temp disable
              72f40-egr enable tps threshold
              72f42-egr disable tps threshold
              72f44-egr enable speed
              72f46-egr disable speed
              743a8-open loop af by RPM vs airmass
              74784-Fuel level percent vs fuel level sensor volts
              7482c-class 2 fan enable
              74834-fan 1 ambient temp
              74838-fan 1 coolant temp
              7483c-fan 1 pressure
              74840-fan 1 coolant vs vehicle speed
              74844-fan 1 pressure vs speed
              7484c-fan 2 coolant temp
              74848-fan 1 keyoff coolant
              7484a-fan 1 keyoff time
              74850-fan 2 pressure
              74854-fan 2 coolant vs speed
              74858-fan 2 pressure vs speed
              7486a-use filtered tps
              7486b-WOT diables AE
              7486c-disable tps closing delta
              74870-AE TPS re-allow
              74872-enable tps delta vs ect
              748be-tps filter coefficient
              748c0-AE disable ref count limit
              748c2-AE modifier vs baro
              748d6-AE MPH modifier
              748e8-AE enrichment vs TPS max delta
              74912-accel enrichment vs ref counts
              74994-startup ae modifier vs ect vs ert-p/n
              74aac-startup ae modifier vs ect vsert-in gear
              74b56-closed loop desired a/f
              74bc4-startup ae modifier ae vs tps.
              74bda-startup ae modifier vs afr correction
              74d48-open loop AF be rpm vs airmass ect threshold
              75390-open loop base af by coolant temp
              753b6-max startup ect for startup AFR coolant
              753bc-max startup ect for startup afr coldstart
              753fc-torque abuse a/f
              753fe-torque abuse differential score a/d
              75400-traction control desired a/f
              7540e-over high MPH limit AFR
              75410-rpm limit afr
              75436-engine over temp a/f ratio
              7546e-base PE a/f vs ECT
              75494-pe rpm vs time a/f
              755c6-PE a/f vs tps
              755f2-Catalytic converter overtemp a/f ratio
              75614-startup a/f enable time vs ect
              75686-startup a/f adjustment by coolant temp
              7587e-decay vs startupvs rpm-p/n
              7590a-decay vs startup vs rpm-in gear
              75a28-hot open loop fuel enable coolant temp
              75a2a-hot open loop fuel disable coolant temp
              75a30-hot open loop fuel IAT thresholds
              75a34-hot open loop fuel MGcyl thresholds
              75a38-hot open loop fuel MPH thresholds
              75a3c-CAT protection coolant
              75bde-engine runtime for cosed loop vs ECT
              75c04-closed loop fuel enable coolant temp
              75c06-closed loop fuel disable coolant temp
              75c0a-closed loop fuel enable RPM
              75c0c-closed loop fuel enable RPM time
              75c12-pe mode delay rpm
              75c14-rpm limit afr time
              75c16-rpm limit afr threshold
              75c18-pe delay vs tps
              75c42-pe enable tps
              75c64-pe enable cylinder mass air vs rpm
              75c86-pe enable mass air threshold hysteresis
              75c88-pe mass air enable threshole modifier vs baro
              75ca6-torque abuse drive rpm
              75caa-torque abuse drive injector disable
              75cab-torque differemtial score injector disable
              75cac-traction control # of injectors disabled vs tc mode
              75cb8-traction disable injectors
              75cc0-min rpm for MPH shutoff
              75cc2-disable all injectors high MPH
              75cce-disable 1 injector high MPH
              75cd0-disable 2 injectors high MPH
              75cd2-high RPM PN fuel cutoff
              75cd6-high RPM REV fuel cutoff
              75cda-high RPM fuel cutoff
              75cde-DFCO disable TPS threshold
              75ce0-DFCO enable coolant temp
              75d00-DFCO enable/disable RPM threshold vs gear
              75d16-DFCO disable vehicle speed
              75d18-DFCO disable vehicle speed (cruise mode)
              75dc6-de use filtered TPS
              75dc8-disable positive tps delta
              75dcc-enable negative tps delta
              75dd0-de tps filter coefficient
              75dd2-de disable ref count limit
              75dd4-decel enlean vs TPS
              75dfe-decel enlean modifer vs ref counts
              75e3c-de modifier vs ect vs gear
              75e64-de modifier vs vacuum
              75e72-low pulse width injector offset vs pulse width vs map
              75fea-prime pulse delay after powerup
              75ffe-injector pulse boundary
              76002-injector offset vs battery voltage
              76062-end of injection pulse vs coolant temp
              760bc-min evap purge percent
              760c0-LTFT enleanment calc enabled
              760c1-fuel trim cals use FTCO table
              760c2-LTFT min ECT
              760c4-LTFT max negative trim
              760ec-LTFT offset for FTcell change
              760fc-blm update enable coolant temp
              760fe-STFT threshold needed to change LTFT
              76106-max LTFT with maf failure
              7610a-min LTFT with maf failure
              76118-max LTFT with evap off
              7611c-max LTFT with evap on
              76120-min LTFT with evap off
              76124-min LTFT with evap on
              76128-FTC3 enable cylair
              7612a-FTC3 disable cylair
              7612c-FTC3 enable TP angle
              7612e-FTC3 disable TP angle
              76130-FTC3 enable RPM delta
              76132-FTC3 disable RPM delta
              76134-FTC1 disable cylair
              76136-FTC enable cylair
              76138-FTC disable TP angle
              7613a-FTC1 enable TP angle
              7613c-FTC enable MAF airflow rate
              7613e-FTC4 disable MAF airflow rate
              76140-FTCO disable RPM
              76142-FTCO enable RPM
              76144-FTCO disable TP angle
              76146-FTCO enable TP angle
              76148-FTCO disable mph
              7614a-FTCO enable MPH
              76156-FT learn min startup ECT
              76158-ft learn min ERT
              7615e-LTFT change vs rich/lean staus vs airmass
              761ee-IFR lookup mode
              76216-injector flow rate
              76252-min injector pulse width
              7625e-crank fuel vs RPM
              762a8-crank fuel correction vs # ref counts
              7636c-crank fuel correction vs crank RPM
              763ae-crank fuel correction vs TPS
              763ba-crank fuel correction vs baro
              763ce-injector skew percent rough idle
              763da-injector skew percent
              7676a-base pulse width correction vs fuel pump flow
              7678c-IPW correction vs IAT
              768a6-2 speed fuel pump
              768aa-fuel pump high speed disable ign volts
              768ac-fuel pump high speed enable IGN volts
              768ae-fuel pump high speed enable MAP
              768b0-fuel pump high speed disable MAP
              768b2-fuel pump high speed enable flow
              768b4-fuel pump high speed disable flow
              768be-fuel pump prime time
              768c4-o2 sensor rich/lean threshold
              768dc-STFT offset vs ftcell
              76918-STFT offset engine cold ect max ect
              7691a-max STFT
              7691e-min STFT
              76922-o2 sensor rich lean transition time at idle
              76926-o2 sensor rich lean transition time vs airmass not idle
              76938-base STFT table vs FTcell
              769c2-CAT diagnostic enable coolant temp
              769c6-o2 rich threshold offset min STFT
              76bd9-enable bank 2 fuel trims
              76bda-fuel mileage DIC readout multiplier
              76bdc-hot light enable coolant temp
              76bde-hot light disable coolant temp
              76be6-IAC motor reset position vs baro
              76bfa-IAC motor reset position offset vs ambient air temp
              76c12-IAC airflow per step
              76c54-IAC airflow correction vs oil temp
              76c68-IAC airflow offset for fan 1 on
              76c7a-IAC airflow offset for fan 2 on
              76c7c-IAC airflow offset vs coolant temp vs ERT
              76cd0-IAC airflow correction vs a/c pressure
              76d02-IAC PN offset hi lo MPH threshold
              76d04-IAC airflow offset for PN vs RPM
              76d48-IAC airflow offset vs gear vs rpm
              76e4a-IAC underflow dead band in PN
              76e4c-IAC underflow dead band in drive
              76e83-IAC overflow dead band vs % tPS
              76f32-IAC correction for a/c snticipate vs a/c pressure
              76f5e-IAC for a/c anticipate correctoin factor vs RPM
              76fd4-IAC pn to drive added steps vs coolant temp
              770f2-IAC rev to drive anticipate steps vs vehicle speed
              7711c-IAC steps added for fan 1 on
              7711e-IAC steps added for fan 2 on
              77320-idle RPM offest vs baro
              7738a-IAC desired idle RPM for trans not engaged
              773d6-IAC desired idle RPM for trans engaged
              775fe-throttle follower disable delay vs gear
              7771c-throttle follower disable filter time constant vs ger
              77d64-throttle follower gain factor vs vehicle speed
              77ff9-use larger table steps
              77ffa-MAP scaling factor
              77ffc-MAP sensor offset
              78000-defaul max map
              780d4-default map vs tps vs rpm
              7824a-default map vs ECT multiplier
              78270-default map vs IAT multiplier
              78296-default map vs egr multiplier
              782ac-o2 sensor b2s1 present
              78304-decel fuel cutoff spark advance
              78306-warmup spark correction vs baro multiplier
              7831a-low octane/bad fuel spark
              785ba-high octane/good fuel spark
              7885a-mean best torque spark
              78afa-decel spark advance multiplier ve coolant temp
              78b0e-decel spark advance multiplier vs ambient temp
              78b22-decel spark advance vs RPM
              78b3e-decel spark disable %tps
              78b40-decel spark enable %tps
              78b44-decel spark advance enable coolant temp
              78b98-torque abuse spark
              78b9a-max allowable spark advance
              78b9c-min allowable spark advance
              78ba0-min allowable spark advance- torque management
              78bbe-egr spark advance correction vs load vs rpm
              78cfe-egr spark advance correction vs load bs rpm, high alt.\
              78e52-launch spark disable vehicle speed
              78e56-launch sparnk enable pos delta TPS
              78e58-launch spark enable pos delta mass air
              78e5a-launch spark disable pos delta mass air
              78e5e-launch spark diasble negative delta TPS
              78e60-launch spark advance correction vs load vs rpm
              78fda-launch spark correction multiplier vs coolant temp
              79002-min power managment spark advance
              79004 power management spark retard vs pm mode
              79012-power managment spark retard adder vs pm mode vs tps
              79106-spark advance p/n correction vs coolant temp
              79140-tcc spark advance correction
              792c0-AFR spark modifier
              791c2-warmup spark correction vs load vs engine runtime
              792d0-air temp spark modifier
              79470-engine coolant temp spark modifier
              796d6-high RPM threshold
              796d8-high RPM spark
              796da-egr spark modifier
              79a50-idle spark enable coolant temp
              78a52-idle spark disable coolant temp
              79a78-idle spark advance vs load vs rpm
              79acc-disable idle spark advance vs ect multiplier
              79ace-idle spark advance multipliervs coolant temp
              79b1a-closed loop idle spark correction afr-ap on
              79b5e-closed loop idle spark correction AFR-ap off
              79ba4-torque differential score retard
              79ba8-high MPH limit
              79bb6-warmup spark correction vs mph multiplier
              79bc8-warmup spark max ert vs startup ect
              79fec-min est signal high time
              79fee-min est signal low time
              79ff0-static dwell time vs reference period
              7a03a-dwell time correction vs battery voltage
              7a068-lower window limit dwell time multiplier vs rpm
              7a08e-upper window limit dwell multiplier vs rpm
              7a0b4-max main dwell table correction vs ign temp ve ign volt
              7a280-max dwell time vs ign volt vs rpm
              7a5ea-dwell time correction vs %egr
              7a9cc-main dwell table correction vs ignition volt
              7ab98-main spark dwell time vs ign volts vs rpm
              7af10-burst knock disable RPM
              7af12-burst knock disable MPH
              7af14-burst knock detection min delta TPS
              7af16-burst knock retard enable coolant temp
              7af1c-max burst knock control
              7af22-cyl air threshold
              7af24-kncok retard recovery rate
              7af46-knock retard decel recovery rate
              7af68-knock retard IR attack rate
              7af92-max allowed spark retard
              7afa0-spark control runtime disable
              7afa2-spark control coolant disable
              7afa4-spark control rpm disable
              7afa6-knock retard defaul value
              7afb4-knock retard default max
              7afc2-default KR vs MgCyl multiplier
              7afe2-default KR vs rpm multiplier
              7aff4-spark control map disable
              7b124-traction mode boost control by torque
              7b126-traction mode boost control disable
              7b128-decel boost control MPH
              7b12a-decel boost control by throttle
              7b12c-integral gain
              7b12e-porportional gain
              7b130-boost ramp rate
              7b132-excess MPH boost reduction gain
              7b134-excess MPH torque reduction scalar
              7b136-excess MPG enable timer
              7b138-excess MPH enable by MPH
              7b6e2-shift pressure 2nd base
              7b724-shift pressure 3rd base
              7b766-shift pressure 4th base
              7b7a8-shift pressure 2nd performance
              7b7ea-shift pressure 3rd performance
              7b82c-shift pressure 4th performance
              7b86e-2nd base pressure correction VS torque vs trans temp
              7b918-3rd base pressure correction vs torque vs trans temp
              7b9c2-4th base pressure correction vs torque vs trans temp
              7ba6c-2nd downshift pressure correction vs torque vs trans temp
              7bb16-3rd downshift pressure correction vs torque vs trans temp
              7bbc0-4th downshift pressure correction vs torque vs trans temp
              7bc6a-braking pressure 1st
              7bc8c-braking pressure 2nd
              7bcae-braking pressure 3rd
              7bd90-2nd upshift pressure multiplier vs torque vs ratio
              7be3a-3rd upshift pressure multiplier vs torque vs ratio
              7bee4-4th upshift pressure multiplier vs torque vs ratio
              7bf96-calculated pulses per revolution
              7bf98-abuse mode duration vs trans temp
              7bfdc-torque reduction 2nd to 1st downshift
              7bffe-torque reduction 3rd to 2nd downshift
              7c020-torque reduction 4th to 3rd downshift
              7c042-torque reduction 1st to 2nd upshift
              7c064-torque reduction 2nd to 3rd upshift
              7c086-torque reduction 3rd to 4th upshift
              7c0a8-torque reduction 1st to 2nd performance upshift
              7c0ca-torque reduction 2nd to 3rd performance upshift
              7c0ce-torque reduction 3rd to 4th performance upshift
              7c130-1st to 2nd normal shift line
              7c152-2nd to 3rd normal shift line
              7c174-3rd to 4th normal shift line
              7c196-2nd to 1st normal line
              7c1b8-3rd to 2nd normal line
              7c1da-4th to 3rd normal line
              7c1fc-2nd to 3rd cruise shift line
              7c21e-3rd to 4th cruise shift line
              7c240-3rd to 2nd cruise shift line
              7c262-4th to 3rd cruise shift line
              7c284-1st to 2nd d2 normal line
              7c2a6-2nd to 3rd d2 normal line
              7c2a8-2nd to 1st d2 normal line
              7c3c2-2nd to 3rd hot normal line
              7c2ca-3rd to 2nd d2 normal line
              7c2cc-1st to 2nd dlow normal line
              7c2ce-2nd to 3rd dlow normal line
              7c2d0-2nd to 1st dlow normal line
              7c2d2-3rd to 2nd dlow normal line
              7c3a0-1st to 2nd hot normal line
              7c3e4-3rd to 4th hot normal line
              7c406-2nd to 1st hot normal line
              7c428-3rd to 2nd hot normal line
              7c44a-4th to 3rd hot normal line
              7c46c-1st to 2nd performance shift
              7c48e-2nd to 3rd performance shift line
              7c4b0-3rd to 4th performance shift line
              7c4d2-2nd to 1st performance shift line
              7c4f4-3rd to 2nd performance shift line
              7c516-4th to 3rd performance shift line
              7c538-1st to 2nd WOT shift
              7c53a-2nd to 3rd wot shift
              7c53c-3rd to 4th WOT shift
              7c53e-2nd to 1st WOT shift
              7c540-3rd to 2nd WOT shift
              7c542-4th to 3rd WOT shift
              7c544-1st to 2nd hot WOT shift
              7c546-2nd to 3rd hot WOT shift
              7c548-3rd to 4th hot WOT shift
              7c54a-2nd to 1st hot WOT shift
              7c54c-3rd to 2nd hot WOT shift
              7c54e-4th to 3rd hot WOT shift
              7c550-1st to 2nd performance WOT shift
              7c552-2nd to 3rd performance WOT shift
              7c554-3rd to 4th performance WOT shift
              7c556-2nd to 1st performance WOT shift
              7c558-3rd to 2nd performance WOT shift
              7c55a-4th to 3rd performance
              7c566-1st to 2nd shift RPM
              7c568-2nd to 3rd shift RPM
              7c56a-3rd to 4th hot shift RPM
              7c56c-1st to 2nd hot shift RPM
              7c56e-2nd to 3rd hot shift RPM
              7c570-3rd to 4th hot shift RPM
              7c578-1st to 2nd performance shift RPM
              7c57a-2nd to 3rd performance shift RPM
              7c57c-3rd to 4th performance shift RPM
              7c584-1st to 2nd dlow urban line
              7c5a6-2nd to 3rd dlow urban line
              7c5c8-2nd to 1st dlow urban line
              7c5ea-3rd to 2nd dlow urban line
              7c85e-TCC apply 2nd normal line
              7c880-TCC apply 3rd normal line
              7c8a2-TCC apply 4th normal line
              7c8c4-TCC release 2nd normal line
              7c8e6-TCC release 3rd normal line
              7c908-TCC release 4th normal line
              7c92a-TCC apply 3rd cruise
              7c94c-TCC apply 4th cruise
              7c96e-TCC release 3rd cruise
              7c990-TCC release 4th cruise
              7c9b2-TCC apply 2nd hot
              7c9d4-TCC apply 3rd hot
              7c9fc-TCC apply 4th hot
              7ca18-TCC release 2nd hot
              7ca3a-TCC release 3rd hot
              7ca5c-TCC release 4th hot
              7ca7e-TCC apply 2nd performance
              7caa0-TCC apply 3rd performance
              7cac2-TCC apply 4th performance
              7cae4-TCC release 2nd performance
              7cb06-TCC release 3rd performance
              7cb28-TCC release 4th performance
              7cd5a-normal TCC release %tps threshold vs gear vs speed
              7cdc0-cruise TCC release %tps threshold vs gear vs speed
              7ce26-performance tcc release %tps threshold vs gear vs speed
              7ce8c-1st to 2nd normal shift time
              7ceae-2nd to 3rd normal shift time
              7ced0-3rd to 4th normal shift time
              7cef2-1st to 2nd performance shift time
              7cf14-2nd to 3rd performance shift time
              7cf36-3rd to 4th performance shift time
              7d08a-shift switch type
              7d08c-discrete switch debounce time
              7d09a-IAT sensor present
              7d09b-shift quality controled by pcm
              7d0a5-trans torque reduction-master enable
              7d0a6-trans abuse mode master enable
              7d0e2-abuse control method
              7d0e4-max turbine torque TCC locked
              7d0fe-max turbine torque TCC unlocked
              7d186-brake torque limit
              7d2a0-torque abuse speed enable
              7d2a2-torque abuse throttle enable
              7d2a6-torque abuse rpm enable
              7d2a8-torque abuse time enable
              7d2b0-torque management engine speed limit
              7d2b4-torque abuse spark retard
              7d2e4-torque abuse differential score mph enable
              7d33c-Catalyst protection boost shutoff
              7d39c-traction control enable coolant temp
              7d5e8-transmission type
              7d5f2-1st gear min rpm/vehicle speed ratio
              7d5fc-2nd gear min rpm/vehicle speed ratio
              7d620-speedometer input pulses per revolution
              7d634-pulses per mile
              7d644-VTD present on car
              7d64e-VTD injector disable time
              7d654-VTD auto learn timer
              7d65c-VTD auto learn counter
              7d70e-tcc slip test fail slip rpm low
              7d710-tcc slip test fail slip rpm high
              7d734-tcc slip diagnostic disable rpm
              7d736-tcc slip diagnostic enable rpm
              7d9ae-max shift pressure
              7d9b0-drive sproket ratio
              7d9d4-first gear ratio
              7d9d6-second gear ratio
              7d9d8-third gear ratio
              7d9da-fourth gear ratio
              7d9dc-reverse gear ratio
              7ea1a-trans abuse mode-min rpm
              7ea1c-trans abuse mode-max trans rpm
              7ea1e-trans abuse mode-min tps%
              7ea22-trans abuse mode-max MPH
              7ea24-trans abuse mode-torque reduction
              7ee4e-downshift delay after tcc unlock
              7eee4-tcc upshift unlock time vs gear
              7eeec-tcc downshift unlock time vs gear
              7effa-tcc dc max-line pressure vs trans temp
              7f076-tcc dc min-line pressure vs trans temp
              7f120-tcc pressure apply rate
              7f9ce-FMC vs CLP vs temp-positive
              7fb0e-torque step size for table lookup
              7fbf4-trans revolutions per mile
              7fffa-prom id
              7fffe-programming complete pattern
              • #67
                whoo... 721 parameters. this is a "L67" bin, about 40 more then the short* bin, but I think it will be able to be adjusted for COP by simply changing the "engine type", and "crank sensor resolution" switches, it also supports boost out of the box, no questions asked.
                there are a couple of oddities in tiny tuner here though;
                two tables, one address
                75a66-pe enrichment rate - rev limit hits for rev limit afr
                one table, two addresses
                6f2f4-speed density maf compensation vs baro
                6f31c----speed density maf compensation vs baro
                I haven't investigated any of it yet.
                1d12a-ect vs voltage
                23c18-injector firing reference vs engine type 1
                23c42-injector firing reference vs engine type 2
                4c544-engine displacement vs engine type
                6ee51-car type
                6ee52-ignore flash checksum
                6ee53-disable flash security
                6ee54-module programmed
                6ee56-engine type
                6ee57-crank sensor resolution
                6ee58-supercharger rpesent
                6ee60-immediate a/c rpm disable
                6ee66-a/c disable rpm
                6ee6a-a/c rpm re-enable
                6ee70-a/c on startup delay
                6ee84-a/c min air temp
                6ee86-a/c disable/re-enable ect
                6ee8a-a/c disable/re-enable tps
                6ee8e-a/c disable timer
                6eea6-a/c ign voltage disable
                6eeaa-a/c ign voltage enable
                6eeb2-maf airflow table
                6ef54-maf max positive airflow change
                6ef7a-maf max negative airflow change
                6f016-transient airmass calc mode
                6f018-max cyl airmass
                6f01e-transient fueling enable positive tps delta
                6f020-transient fueling enable negative tps delta
                6f028-default mass airflow (gm/sec) vs tps vs rpm
                6f2f2-maf failure airmass calc mode
                6f308-speed density maf compensation vs ect
                6f3b4-volumetric efficiency
                6f5b2-ve correction vs tps vs egr state
                6f5ca-speed sensity maf compensation vs IAT
                6f75e-air pump system present
                6f774-air pump enable startup coolant temp
                6f7a8-alternator startup delay vs ect
                6f7bc-alternator rpm cutout
                6f840-default baro
                6f842-always use default baro
                6f846-sc baro lookup
                6f888-na baro lookupvs tps vs rpm
                6faa4-o2sensor config for pid 13
                6faa6-boost delay-boost timer base
                6fabc-boost delay-timer adder-tcs on
                6fb00-boost delay-timer adder-tcs off
                6fb54-CCP enable coolant temp
                700a6-ect ok enable ert
                700a8-ect ok enable ect
                700aa-ect ok disable ect
                700ac-ect ok enable dtc set
                700ae-ect ok disable ect dtc set
                700b0-ect temp vs ert
                7031c-knock sensor diagnostic min ect
                7031e-knock sensor diagnostic min engine load
                70320-knock sensor diagnostic rpm thresholds
                7032e-knock sensor diagnostic min ert
                70332-knock sensor circuit diagnostic min fails per sample to set DTC
                70334-knock sensor circuit diagnostic test sample size
                70336-knock sensor diagnostic min fails per sample to set dtc
                70338-knockc sensor diagnostic test sample size
                7033a-knock sensor diagnostic max KR
                7033c-knock sensor diagnostic min tps
                7033e-knock sensor diagnostic min ignv
                70f4c-flash checksum
                70f7a-CAT diagnostic tests per trip
                70f7c-CAT diagnostic count to fail
                70f82-idle diagnostic min tests failed to set dtc
                70f8a-max idle rpm variance vs ect
                70fda-cam and crank sensor circuit min ert
                70fdc-p0341 min fails per sample to set dtc
                70fde-p0341 test sample size
                70fe0-p0336 min fails per sample to set dtc
                70fe2-p0336 test sample size
                70fe4-p1374 min fails per sample to set dtc
                70fe6-p1374 test sample size
                71080-p0103 min fails per test sample to set dtc
                71082-p0103 test sample size
                71084-max maf frequency
                71086-p0102 min fails per test to set dtc
                71088-p0102 test sample size
                7108a-min maf frequency
                7108c-p0101 min fails per sample to set dtc
                7108e-p0101 test sample size
                71090-max delta airflow
                710a6-p0106 max map volts vs tps vs rpm
                71140-p0106 min map volts vs tps vs rpm
                711da-p0108 and p1106 min fails per test sample to set dtc
                711dc-p0108 and p1106 test sample size
                711de-p1107 min fails per sample to set dtc
                711e0-p1107 test sample size
                711e2-p0106 number of times out of range to set p0106
                711e6-p0108 min fails per test sample to set dtc
                711e8-p0108 rpm threshold
                711ea-p0108 test sample size
                711ec-p0107 min fails per test sample to set dtc
                711ee-p0107 rpm threshold
                711f0-p0107 test sample size
                711f3-p0108 min map volts
                711f4-p0107 max map volts
                711f6-p0108 max tps above rpm threshold
                711f8-p0107 min tps above rpm threshold
                711fa-p0108 max tps below rpm threshold
                711fc-p0107 max tps below rpm threshold
                71202-p1112 min mph
                71204-p0113 min ect
                71206-p0113 max airmass
                71208-p0113 max mph
                7120a-p0113 min ert
                7120e-p1112 min ert
                71213-p0112 min raw iat count
                71214-p0113 max raw iat count
                71216-p1111 and p1112 tests sample size
                71218-p0113 min fails per test sample to set dtc
                7121a-p0112 min fails per test sample to set dtc
                7121c-p1111 min fails per test sample to set dtc
                7121e-p1112 min fails per test sample to set dtc
                71220-p0112 and p0113 test sample size
                71222-p0030 fail time
                71224-p0030 ign v thresholds
                71228-p0230 fail time
                7122a-p0230 ign v thresholds
                7122e-p0403 fail time
                71230-p0403 ign v thresholds
                71234-p0654 fail time
                71236-p0654 ign v thresholds
                7123a-p1689 fail time
                7123c-p1689 ign v thresholds
                712ac-p1121 min fails per test sample to set dtc
                712ae-p1121 test sample size
                712b0-p1122 min fails per test sample to set dtc
                712b2-p1122 test sample size
                712b4-p0121 min ect
                712b6-p0121 min ert
                712b8-p0121 min fails per test sample to set dtc
                712ba-high tps diagnostic error max map-p0121
                712bc-low tps diagnostic min map
                712c2-p0121 test sample size
                712c4-p0123 min fails per test sample to set dtc
                712c6-p0123 test sample size
                712c8-p0122 min fails per test sample to set dtc
                712ca-p0122 test sample size
                712cc-p0123 min tps volts
                712ce-p0122 max tps volts
                712d0-high tps diagnostic predicted tps vs rpm
                712f0-low tps diagnostic predicted tps vs rpm
                71862-misfire max delta time low rpm cyl mode
                71994-misfire max delta time mid rpm cyl mode
                71ae8-misfire max delta time high rpm cyl mode
                71c1a-misfire max delta time low rpm rev mode
                71ea0-misfire max delta time high rpm rev mode
                71d4c-misfire max delta time mid rpm rev mode
                7200a-misfire firing order lookup
                7201c-misfire detection coldstart ect definition
                72014-misfire detection disable coolant temp
                72016-misfire detection enable coolant temp
                7201a-misfire detection min ect coldstart
                7201e-misfire detection high rpm threshold
                72020-misfire detection low rpm threshold
                72092-p0130 and p0150 min ect
                72096-p0130 and p0150 min ert
                7209a-p0130 and p0150 rpm thresholds
                720a0-p0130 and p0150 airmass thresholds
                720a4-p0130 and p0150 ign v thresholds
                720a6-p0130 and p0150 conditions enable time
                720a8-p0130 and p0150 tps thresholds
                72204-p0132 and p0152 min fails per sample to set dtc while in pe
                72206-p0138 min fails per sample to set dtc while in pe
                7220a-p0132 and p0152 test sampel size while in pe
                7220c-p0138 test sample size while in pe
                72210-p0132 and p0152 max o2 mv in dfco
                72211-p0138 max o2 mv in dfco
                72218-p0131 and p0151 min fails per sample to set dtc
                7221a-p0137 min fails per sample to set dtc
                72230-p0131 and p0151 test sample size
                72232-p0137 test sample size
                72236-p0131 and p0151 max o2 mv
                72237-p0137 max o2 mv
                72248-p0134 and p0154 min fails per sample to set dtc
                7224a-p0140 min fails per sample to set dtc
                7224e-p0134 and p0154 max o2 mv
                7224f-p0140 max o2 mv
                72252-p0134 and p0154 min o2 mv
                72253-p0140 min o2 mv
                72256-p0134 and p0154 test sample size
                72258-p0140 test sample size
                7225c-p0131 and p0151 min fails per sample to set dtc while in pe
                7225e-p0137 min fails per sample to set dtc while in pe
                72262-p0131 and p0151 test sample size while in pe
                72264-p0137 test sample size
                72268-p0131 and p0151 max mv while in pe
                72269-p0137 max mv while in pe
                72286-p0132 and p0152 min fails per sample to set dtc
                72288-p0138 min fails per sample to set dtc
                72292-p0132 and p0152 max o2 mv
                72293-p0138 max o2 mv
                7229e-p0132 and p0152 test sample size
                722a0-p0138 test sample size
                72988-fuel trim diagnostic min baro
                7298a-fuel trim diagnostic ect thresholds
                72990-fuel trim diagnostic airmass thresholds
                72998-fuel trim diagnostic min fuel level
                7299a-fuel trim diagnostic map kpa thresholds
                7299e-fuel trim diagnostic iat thresholds
                729a6-fuel trim diagnostic intrusive mode airmass thresholds
                729ae-fuel trim diagnostic intrusive mode min rpm
                729b6-fuel trim diagnostic RPM thresholds
                729ba-fuel trim diagnostic max MPH
                729fc-idle diagnostic min baro
                729fe-idle diagnostic min ect
                72a00-idle diagnostic min ert
                72a04-idle diagnostic min iat
                72a06-idle diagnostic ign v threshold
                72a0e-idle diagnostic max tps
                72a10-idle diagnostic max MPH
                72a16-p0102 and p0103 min ert
                72a1a-p0102 and p0103 min iac steps
                72a1c-p0102 and p0103 min ign v
                72a1e-p0102 and p0103 min rpm
                72a20-p0102 and p0103 criteria enable time
                72a22-p0101 egr limits
                72a26-p0101 max map
                72a28-p0101 ign v thresholds
                72a2e-p0101 max airmass
                72a30-p0101 max delta map
                72a32-p0101 max evap purge percent
                72a34-p0101 criteria enable time
                72a36-p0101 tps thresholds
                72a62-dtc fault type
                72b54-dtc fault enabled
                72d3c-egr disable run time vs startrun coolant
                72d8c-egr air temp disable
                72d90-egr enable tps threshold
                72d92-egr disable tps threshold
                72d94-egr enable speed
                72d96-egr disable speed
                73938-enable oil pressure warning light
                741f8-open loop af by rpm vs airmass
                745d4-fuel level percent vs fuel level sensor volts
                7467c-class 2 fan enable
                74684-fan 1 ambient temp
                74688-fan 1 coolant temp
                7468c-fan 1 pressure
                74690-fan 1 coolant temp vs vehicle speed
                74694-fan 1 pressure vs speed
                74698-fan 1 keyoff coolant
                7469a-fan 1 keyoff time
                7469c-fan 2 temp
                746a0-fan 2 pressure
                746a4-fan 2 coolant temp
                746a8-fan 2 pressure vs speed
                746ba-use filtered tps
                746bb-WOT disables AE
                746bc-ae disable tps closing delta
                746c0-ae tps re-allow
                746c2-enable tps delta vs ect
                7470e-TPS filter coefficient
                74710-ae disable ref count limit
                74712-ae modifier vs baro
                74726-ae mph modfier
                74738-ae enrichment vs tps max delta
                74762-accel enrichment vs ref counts
                747e4-ae modifier vs ect vs ert -in gear
                748fc-ae modifier vs ect ve ert -p/n
                74a14-startup ae modifier vs tps
                74a2a-startup ae modifier vs afr correction
                74a36-closed loop desifred a/f ratio
                74b98-open look af by rpm vs airmass ect threshold
                74b9c-open loop af by rpm vs airmass cold ect
                74ebc-open loop af by rpm vs airmass hot ect
                751e0-open loop base af by coolant temp
                75206-max startup ect for startup afr
                75208-additional ect needed to disable coldstart status for afr vs startup ect
                7524c-torque abuse a/f
                7524e-torque abuse differential score a/f
                75250-traction control desired a/f
                7525e-over high mph limit afr
                75260-rev limit mode afr
                75286-engine over temp base a/f ratio
                752be-base pe a/f vs ect
                752e4-pe rpm vs time vs a/f
                75416-pe a/f vs tps
                75443-catalytic converter overtemp a/f ratio
                75464-startup enable time vs ect
                754d6-startuip a/f adjustment by coolant temp
                756ce-decay vs startup ect vs rpm-p/n
                7575a-decay vs startup ect vs rpm-in gear
                75878-hot open loop fuel enable coolant temp
                7587a-hot open loop fuel disable coolant temp
                7587e-hot open loop fuel conditions enable time
                75880-hot open loop fuel iat thresholds
                75884-hot open loop fuel mg/cyl thresholds
                75888-hot open loop fuel mph thresholds
                7588c-CAT protection coolant
                758a2-closed loop max airmass
                758a4-closed loop disable airmass
                75a2e-engine runtime for closed loop vs ect
                75a54-closed loop fuel enable coolant temp
                75a56-closed loop fuel disable coolant temp
                75a58-closed loop rpm enable max ect
                75a5a-closed loop fuel enable rpm
                75a5c-closed loop fuel enable rpm time
                75a5e-closed loop o2 mv disable time
                75a60-closed loop o2 mv thresholds
                75a62-pe mode delay rpm
                75a64-rev limit afr active time
                75a68-pe delay vs tps
                75a92-pe anable tps
                75ab4-pe enable cylinder airmass vs rpm
                75ad6-pe enable mass air thresh hysteresis
                75ad8-pe mass air enable threshole modifier vs baro
                75af6-torque abuse drive rpm
                75afa-torque abuse drive injector disable
                75afb-torque differential score injector disable
                75afc-traction control # of injectors disabled vs tc mode
                75b08-traction disable injectors
                75b10-min rpm for mph shutoff
                75b12-disable all injectors high MPH
                75b1e-disable 1 injector high mph
                75b20-disable 2 injectors high MPH
                75b22-high rpm pn fuel cutoff
                75b26-high rpm rev fuel cutoff
                75b2a-high rpm fuel cutoff
                75b2e-DFCO disable tps threshold
                75b30-DFCO enable coolant temp
                75b50-DFCO enable/disable rpm threshold vs gear
                75b66-DFCO disable vehicle speed
                75b68-DFCO disable vehicle speed (cruise mode)
                75c16-de use filtered tps
                75c18-disable positive TPS delta
                75c1c-enable negative tps delta
                75c20-de tps filter coefficient
                75c22-DE disable ref count limit
                75c24-decel enlean vs tps
                75c4e-decel enlean modifier vs ref counts
                75c8c-de modifier vs ect vs gear
                75cb4-de modifier vs vacuum
                75cc2-low pulse width injector offset vs pulse width vs map
                75e3a-prime pulse delay after powerup
                75e4e-injector pulse boundry
                75e52-injector offset vs battery voltage
                75eb2-end of injection pulse vs coolant temp
                75f10-min evap purge pct
                75f14-LTFT enaleanment calc enabled
                75f15-fuel trim calc use ftc0 table
                75f16-LTFT min ect
                75f18-LTFT max negative trim
                75f40-LTFT offset for FTCell change
                75f50-blm update enable coolant temp
                75f52-STFT threshold needed to change LTFT
                75f5a-max LTFT with maf failure
                75f5e-min LTFT with maf failure
                75f6c-max LTFT with evap off
                75f70-max LTFT with evap on
                75f74-min LTFT with evap off
                75f78-min LTFT with evap on
                75f7c-FTC3 mg/cyl thresholds
                75f7e-FTC3 disable cylair
                75f80-FTC3 TPS thresholds
                75f82-FTC3 disable tp angle
                75f84-FTC3 rpm thresholds
                75f86-FTC3 disable RPM delta
                75f88-FTC1 mg/cyl thresholds
                75f8a-ftc1 enable cylair
                75f8c-FTC1 tps thresholds
                75f8e-FTC1 enable tp angle
                75f90-ftc4 mg/cyl thresholds
                75f92-FTC4 disable MAF airflow rate
                75f94-FTC0 idle variance thresholds
                75f96-FTC0 enable RPM
                75f98-FTC0 tps thresholds
                75F9a-FTC0 enable TPangle
                75f9c-FTC0-mph thresholds
                75f9e-FTC0 enable MPH
                75fac-FT learn min ert
                75fb2-LTFT change vs rich/lean status vs airmass
                76042-IFR lookup mode
                7606a-injector flow rate
                790a6-min injector pulse width
                760b0-max ect for crank fuel ref count multiplier
                760b2-crank fuel vs coolant temp
                760fc-crank fuel correction vs # ref counts
                761c0-crank fuel correction vs crank rpm
                76202-crank fuel correction vs tps
                7620e-crank fuel correction vs baro
                76222-injector skew percent rough idle
                7622e-injector skew percent
                765be-base pulse width correction vs fuel pump flow
                765e0-IPW correction vs IAT
                766fa-2speed fuel pump
                766fe-fuel pump high speed disable ign volts
                76700-fuel pump high speed enable ign volts
                76702-fuel pump high speed enable map
                76704-fuel pump high speed disbale map
                76706-fuel pump high speed enable flow
                76708-fuel pump high speed disable flow
                76712-fuel pump prime time
                76718-o2 sensor rich lean threshold
                76730-STFT offset vs ect
                7676a-max STFT
                7676c-STFT offset engine cold MAX ECT
                76772-min ftft
                76776-o2 sensor rich lean transistion time at idle
                7677a-o2 sensor rich lean transition time vs airmass not idle
                7678c-base stft table vs ft cell
                76816-CAT diagnostic enable coolant temp
                7681a-o2 rich threshold offset min stft
                76a2d-enable 2 bank fuel trims
                76a2e-fuel milage DIC readout multiplier
                76a30-hot light enable coolant temp
                76a32-hot light disable coolant temp
                76a3a-iac motor reset position vs baro
                76a4e-iac motor reset position offset vs ambient air temp
                76a66-iac airflow per step
                76a96-iac airflow correction vs ac pressure mph multiplier
                76aa8-iac airflow correction vs oil temp
                76abc-iac airflow offset for fan 1 on
                76abe-iac airflow offset for fan 2 on
                76ac0-iac airflow offset vs coolant temp vs engine run time
                76b24-IAC airflow correction vs a/c pressure
                76b56-iac p/n offset hi lo mph threshold
                76b58-iac airflow offset for p/n vs rpm
                76b9c-iac airflow offset vs gear vs rpm
                76c90-iac underflow dead band-in drive
                76c9e-iac underflow dead band-p/n
                76cd6-iac overflow deadband vs tps%
                76d60-iac correction for ac anticipate vs ac pressure
                76db2-iac for ac anticipate correction factor vs rpm
                76e28-iac p/n to drive added steps vs coolant temp
                76f46-iac rev to drive anticipate steps vs vehicle speed
                76f70-iac steps added for fan 1 on
                76f72-iac steps added for fan 2 on
                77174-idle rpm offset vs baro
                771de-iac desired idle rpm trans not engaged
                7722a-iac desired idle rpm trans engaged
                77464-throttle follower disable delay vs gear
                7753a-throttle folloer gain factor vs vehicle speed
                77582-throttle follower disable filter time constant vs gear
                77e5f-spark table air mass scale
                77e60-map scaling factor
                77e62-map sensor offset
                77e66-default max map
                77f3a-default map vs tps vs rpm
                780b0-default map vs ect multiplier
                780d6-default map vs iat multiplier
                780fc-default map vs egr% multiplier
                78112-o2 sensor b2s1 present
                7816a-decel fuel cutoff spark advance
                7816c-warmup spark correction vs baro multiplier
                78180-low octane/bad fuel spark
                78420-high octane/good fuel spark
                786c0-mean best torque spark
                78960-decel spark advance multiplier vs coolant temp
                78974-decel spark advance multiplier vs ambient temp
                78988-decel spark advance vs rpm
                789a4-decel spark disable tps
                789a6-decel spark enable tps
                789aa-decel spark advance enable coolant temp
                789fe-torque abuse spark
                78a00-max allowable spark advance
                78a02-min allowable spark advabce
                78a10-max spark advance in pe
                78a24-egr spark adv. correction vs load vs rpm
                78b64-egr spark adv. correction vs load ve rpm high alt
                78cb8-launch spark disable vehicle speed
                78cbc-launch spark enable positive delta tps
                78cbe-launch spark enable pos delta mass air
                78cc0-launch spark disable pos delta mass air
                78cc4-launch spark disable negative delta tps
                78cc6-launch spark advance correction vs load vs rpm
                78e40-launch spark correction multiplier vs coolant temp
                78e68-min power management spark advance
                78e6a-power management spare retard vs pm mode
                78e78-power management spark retard adder vs pm mode vs tps
                78f6c-spark advance p/n correction vs coolant temp
                78fa6-tcc spark advance correction
                79028-warmup spark correction vs load ve engine runtime
                79126-afr spark modifier
                79136-air temp spark modifier
                792d6-engine coolant temp spark modifier
                7953c-high rpm threshold
                7953e-high RPM spark
                79540-crank spark advance vs rpm vs coolant temp
                798b4-disable idle spark advance
                798b6-idle spark enable coolant temp
                798b8-idle spark disable coolant temp
                798de-idle spark advance vs load vs rpm
                79932-disable idle spark advance vs ect multiplier
                79934-idle spark advance multiplier vs coolant temp
                79980-closed loop idle spark correction-ap on
                799c4-closed loop idle spark correction-ap off
                79a0a-torque differential score retard
                79a0e-high MPH limit
                79a1c-warmup spark correction vs mph multiplier
                79a2e-warmup spark max ert vs ect
                79e52-min est signal high time
                79e54-min est signal low time
                79e56-static dwell time vs reference period
                79ea0-dwell time correction vs batt voltage
                79ece-lower window limit dwell time multiplier vs rpm
                79ef4-upper window limit dwell time multiplier vs rpm
                79f1a-max dwell table correction vs ign temp vs ign volt
                7a0e6-max dwell time vs ign volt vs rpm
                7a450-dwell time correction vs %egr
                7a832-main dwell table correction vs ign temp vs ign volt
                7a9fe-main spark dwell time vs ign volt vs rpm
                7ad76-burst kr detection min rpm
                7ad78-burst knock disable mph
                7ad7a-burst kr detection min delta tps
                7ad7c-burst kr detection max ect
                7ad82-max burst knock retard
                7ad88-cyl air threshold
                7ad8a-knock retard recovery rate
                7adac-knock retard decel recovery rate
                7adce-knock retard ir attack rate
                7adf8-max allowed spark retard
                7aeo6-spark control runtime disable
                7ae08-spark control coolant disable
                7aeoa-spark control rpm disable
                7ae0c-knock retard default value
                7ae1a-knock retard default max
                7ae28-default kr vs mgcyl multiplier
                7ae48-default kr vs rpm multiplier
                7ae5a-spark control map disable
                7af8a-traction mode boost control by torque
                7af8c-traction mode boost enable control*** error msg in tiny tuner when clicked
                7af8e-decel boost control MPH
                7af90-decel boost control by throttle
                7af92-integral gain
                7af94-porportional gain
                7af96-boost ramp rate
                7af98-excess MPH boost reduction gain
                7af9a-excess mph reduction scalar
                7af9c-excess MPH enable timer
                7af9e-excess mph enable by MPH
                7b07e-dtc disables shift adapts
                7b0fe-dtc forces 2nd gear
                7b17e-dtc disables 3 to 2 downshift above 30 MPH
                7b27e-dtc disables 4th gear
                7b2be-dtc disables 4th gear in hot mode
                7b33e-DTC forces max line pressure
                7b47e-dtc forces extra line pressure
                7b4f5-dtc disables tcc lockup
                7b5fe-shift pressure 2nd base
                7b640-shift pressure 3rd base
                7b682-shift pressure 4th base
                7b6c4-shift pressure 2nd performance
                7b706-shift pressure 3rd performance
                7b748-shift pressure 4th performance
                7b78a-2nd base correction vs torque vs trans temp
                7b834-3rdbase correction vs torque vs trans temp
                7b8de-4th base correction vs torque vs trans temp
                7b988-2nd downshift pressure correction vs torque vs trans temp
                7ba32-3rd downshift pressure correction vs torque vs trans temp
                7badc-4th downshift pressure correction vs torque vs trans temp
                7bb86-braking pressure 1st
                7bba8-braking pressure 2nd
                7bbca-braking pressure 3rd
                7bcac-2nd upshift pressure multiplier vs torque vs ratio
                7bd56-3rd upshift pressure multiplier vs torque vs ratio
                7be00-4th upshift pressure multiplier vs torque vs ratio
                7beb2-calculated pulses per revolution
                7beb4-abuse mode duration vs trans temp
                7bef8-torque reduction 2nd to 1st downshift
                7bf1a-torque reduction 3rd to 2nd downshift
                7bf3c-torque reduction 4th to 3rd downshift
                7bf5e-torque reduction 1st to 2nd upshift
                7bf80-torque reduction 2nd to 3rd upshift
                7bfa2-torque reduction 3rd to 4th upshift
                7bfc4-torque reduction 1st to 2nd performance upshift
                7bfe6-torque reduction 2nd to 3rd performance upshift
                7c008-torque reduction 3rd to 4th performance upshift
                7c04c-1st to 2nd normal shift line
                7c06e-2nd to 3rd normal shift line
                7c090-3rd to 4th normal shift line
                7c0b2-2nd to 1st normal line
                7c0d4-3rd to 2nd normal line
                7c0f6-4th to 3rd normal line
                7c118-2nd to 3rd cruise shift line
                7c13a-3rd to 4th cruise shift line
                7c15c-3rd to 2nd cruise shift line
                7c17e-4th to 3rd cruise shift line
                7c1a0-1st to 2nd d2 normal line
                7c1c2-2nd to 3rd d2 normal line
                7c1c4-2nd to 1st d2 normal line
                7c1e6-3rd to 2nd d2 normal line
                7c1e8-1st to 2nd dlo normal line
                7c1ea-2nd to 3rd dlo normal line
                7c1ec-2nd to 1st dlo normal line
                7c1ee-3rd to 2nd dlo normal line
                7c2bc-1st to 2nd hot normal line
                7c2de-2nd to 3rd hot normal line
                7c300-3rd to 4th hot normal line
                7c322-2nd to 1st hot normal line
                7c344-3rd to 2nd hot normal line
                7c366-4th to 3rd hot normal line
                7c388-1st to 2nd performance shift
                7c3aa-2nd to 3rd performance shift line
                7c3cc-3rd to 4th performance shift line
                7c3ee-2nd to 1st performance shift line
                7c410-3rd to 2nd performance shift line
                7c432-4th to 3rd performance shift line
                7c454-1st to 2nd wot shift
                7c456-2nd to 3rd wot shift
                7c458-3rd to 4th wot shift
                7c45a-2nd to 1st wot shift
                7c45c-3rd to 2nd wot shift
                7c45e-4th to 3rd wot shift
                7c460-1st to 2nd hot WOT shift
                7c462-2nd to 3rd hot wot shift
                7c464-3rd to 4th hot wot shift
                7c466-2nd to 1st hot wot shift
                7c468-3rd to 2nd hot wot shift
                7c46a-4th to 3rd hot wot shift
                7c46c-1st to 2nd performance wot shift
                7c46e-2nd to 3rd performance wot shift
                7c470-3rd to 4th performance wot shift
                7c472-2nd to 1st performance wot shift
                7c474-3rd to 2nd performance wot shift
                7c476-4th to 3rd performance
                7c482-1st to 2nd shift rpm
                7c484-2nd to 3rd shift rpm
                7c486-3rd to 4th shift rpm
                7c488-1st to 2nd hot shift rpm
                7c48a-2nd to 3rd hot shift rpm
                7c48c-3rd to 4th hot shift rpm
                7c494-1st to 2nd performance shift rpm
                7c496-2nd to 3rd performance shift rpm
                7c498-3rd to 4th performance shift rpm
                7c4a0-1st to 2nd dlo urban line
                7c4c2-2nd to 3rd dlo urban line
                7c4e4-2nd to 1st dlo urban line
                7c506-3rd to 2nd dlo urban line
                7c77a-TCC apply 2nd normal
                7c79c-TCC apply 3rd normal line
                7c7be-TCC apply 4th normal line
                7c7e0-tcc release 2nd normal line
                7c802-tcc release 3rd normal line
                7c824-tcc release 4th normal line
                7c846-TCC apply 3rd cruise
                7c868-TCC apply 4th cruise
                7c88a-tcc release 3rd cruise
                7c8ac-tcc release 4th cruise
                7c8ce-TCC apply 2nd hot
                7c8f0-TCC apply 3rd hot
                7c912-TCC apply 4th hot
                7c934-tcc release 2nd hot
                7c956-tcc release 3rd hot
                7c978-tcc release 4th hot
                7c99a-TCC apply 2nd performance
                7c9bc-TCC apply 3rd performance
                7c9de-TCC apply 4th performance
                7ca00-tcc release 2nd performance
                7ca22-tcc release 3rd performance
                7ca44-tcc release 4th performance
                7cc76-normal tcc release %tps threshold vs gear vs speed
                7ccdc-cruise tcc release %tps threshold vs gear vs speed
                7cd42-performance tcc release %tps threshold vs gear vs speed
                7cda8-1st to 2nd normal shift time
                7cdca-2nd to 3rd normal shift time
                7cdec-3rd to 4th normal shift line
                7ce0e-1st to 2nd performance shift time
                7ce30-2nd to 3rd performance shift time
                7ce52-3rd to 4th performance shift time
                7cfa6-shift switch type
                7cfa8-disrete switch debounce time
                7cfb8-iat sensor present
                7cfb9-shift quality controled by pcm
                7d002-abuse mode control method
                7d004-max turbine torque tcc locked
                7d01e-max turbine torque tcc unlocked
                7d0a6-brake torque limit
                7d1c2-torque abuse speed enable
                7d1c4-torque abuse throttle enable
                7d1c8-torque abuse rpm enable
                7d1ca-torque abuse time enable
                7d1d2-torque management engine speed limit
                7d1d6-torque abuse spark retard
                7d208-torque abuse differential score MPH threshold
                7d260-catalyst protection boost shutoff
                7d2c0-traction control enable coolant temp
                7d50c-transmission type
                7d516-1st gear min rpm/vehicle speed ratio vs MPH
                7d520-2nd gear min rpm/vehicle speed ratio vs MPH
                7d544-speedometer input pulse per revolution
                7d558-pulses per mile
                7d568-vtd present on car
                7d572-vtd injector disable time
                7d578-vtd auto learn timer
                7d580-vtd autolearn counter
                7d632-tcc slip test fail slip rpm low
                7d634-tcc slip test fail slip rpm high
                7d659-tcc slip diagnostic disable rpm
                7d65a-tcc slip diagnostic enable rpm
                7d8d0-max shift pressure
                7d8d2-drive sprocket ratio
                7d8f6-first gear ratio
                7d8f8-second gear ratio
                7d8fa-third gear ratio
                7d8fc-fourth gear ratio
                7d8fe-reverse gear ratio
                7e942-trans abuse mode-min tp%
                7e93e-trans abuse mode-min rpm
                7e940-trans abuse mode-max trans rpm
                7e946-trans abuse mode-max MPH
                7e948-trans abuse mode-torque reduction
                7ed76-downshift delay after tcc unlock
                7ee0c-tcc upshift unlock time vs gear
                7ee14-tcc downshift unlock time vs gear
                7efaa-tcc dc max-line pressure vs trans temp
                7f9ce-FMC vs CLP vs Temp
                7fb22-extra line pressure from dtc
                7fffa-prom id
