i started tuning my car and i think am getting the hang of it but when i tried to get stft and ltft close to zero during idle it raised my idle to around 1200-1400, my stft and ltft were maxed out lean before hand and it idled fine, i got my stft to zero and the ltft is still in the sevenish range, but what can i do to get my idle back down. the commanded idle is around 900. makes it hard to shift with a higher idle. i have a log but for some reason logging with powrtuners it losses rpm.
idle tuning
Log your IAC count and see what it is... If he's commanding 900 and getting 1200 or higher than there is a VAC leak somewhere.
what version of DHP are you using? and how is the logging setup? Direct to CSV? or internal Log file?
Stock 3500 cam. It was warmed up all the way. I will log the iac, I forgot to add that one, and uvscan likes to blue screen on me while logging. Am thinking vac leak but it idles stable. It idled low before I started changing the ve and mad table in the idle range. Every time I bumped the ve up it lowered the ltft but my idle rose alittle. Right when it starts it idles right but then the stft starts moving and the idle goes up. I now changed it to export to csv see if that helps the logs. Does any one of a ported with heads bin file I could compare. I had to add a lot to the idle area to get the trims down.
VAC leak will still idle stable, just higher than commanded usually and you'll have a 0 IAC count. Which version of UVScan? I have one that I use regularly and never locks up on me.
well i guess it was a vac leak after all. idles good right now, just need to fine tune the ve and maf table to smooth it out. well pretty much restart the tune again. my last log lost the rpms. it shows it in the gauge the entire time. i guess uninstall and reinstall, i need to figure out uvscan to. but it sucks getting blue screened and losing the log.
I'll get you some UVScan info, and yeah any vac leak will just destroy a tune so it's best to start over again, an honestly it's necessary.
