im installing a 3500 into my fiero, and using a 98ecu, i have most of it figured out and compleated, so the first problem/question i have is the knock sensors...
are the new knock sensors compatible with the 98ecu? if so, how would i wire them?
looking at the diagram theres a twisted pair, then a 3rd wire thats labeled as "drain"
im assuming if they are compatible the drian would be a pcm shared ground, the 1twisted would be 5v ref, and the other the signal wire?
next question... are the cam sensors compatible from the 98ecu to the 06 engine?
