OK, well my tune is starting to come together,
I was quite rich right off the start which I thought was weird, I thought I would be lean to start. I have a fair bit of Spark Knock, (though slightly less now that I am not so rich? ) Also I never seem to enter DE mode?
So this is pretty much a 3 part question lol.
I attach my Bin file here -> http://planethax.com/wz3500vemafbigtest235injrate.bin
Question 1, Why am I never going into DE mode?
I have a Manual Trans using 01 Impala Pcm, the PCM thinks its in first gear?
Do I need to change values in Tiny Tuner? I see many values in TT for DE but not sure what all they do? (and what it meaznt by TPS "Delta" ? )
Question 2, I seem to get KR upto 8-10 with moderate throttle 15-25%?
Was worse when I was very rich, I guess too rich can increase CC temps as well.
What all could be causing this? I used AC Delco plugs 41-101, should I find something cooler? (seen reference to autolites, but have not found them here in Canada yet, at least not with my suppliers)
I have been thinking it was my Cat plugged causing the high KR and Rich condition, but at idle (neutral, clutch applied) my Map is 29 to 30 kpa, If cat was plugged I would think it would be closer to 45-50kpa? any suggestions?
Last quick Item, in TT I see under Injector
Fuel Pump Prime Time, my is set at 0 seconds, but I do have a prime?
I Set to 300 seconds to see if it would lengthen it but did not, also checked to see if it gave a "prime or run on" after shut down but didn't do that either.
What is this for?
What is this for?
