Initial scan, hunting idle
  • Initial scan, hunting idle
    3500 using 3400 Pcm and GTP injectors (flow rate 220)
    Idle is hunt a bit 25 to 50 Rpm, worse the lower the idle.
    I used Tech2 and idle smooths out after 1100 commanded Rpm.
    Checked for Vac leaks, none.
    here is a quick scan at Operating temp.
    edit, should also mention that this is a Manual trans.
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    fueling is off. I don't know if 220 is right or not as DHP is different values than HPT.
      What tells you my fueling is off?
      My AFPR from TCE doesnt seem to be working correctly, pressure is @ 55psi with or without vacuum.
      This is how I came with my IFR for injectors
      using GTP injectors
      Stock injectors for the 3400 were 22.5 @ 55psi
      Gtp are 36 @ 50psi
      stock IFR for the 3400 with 22.5 @ 55psi is 371
      by staying with the Stock 55psi they would flow 37.7571
      So 22.5/37.7571 = .5959 * stock 371 IFR, new IFR would be 221.
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
        That is odd that it doesn't change pressure with vacuum.
        What PSI are those injectors at for their 36# rating? your LTFT tells me your fueling is off.
          the 36# were at 50psi, so I converted that to 55psi they would flow 37.7571
          Something really off with the afpr, if I lower the psi below 50 the Vacuum seems to change the pressure,
          As of April 2
          Injectors: #36 GTPs
          TB: 65mm TCE
            Might be because its based on a stock regulator and they wouldn't increase above 50 based on vacuum alone.
              May have to get a stock fpr and recheck, then if it works better, transfer the TCE cap over.
              You think this would cause the idle hunt?
              Basically a Stock 3400 tune except for Injector flow rate and some DTCs, I am just starting out the tune.
              Engine went in this weekend.
              3rd Gen Cavalier
              As of April 2
              Injectors: #36 GTPs
              TB: 65mm TCE
                Any tips?
                Wideband bung should be here this morning, and replacing fuel filter as well.
                Not sure if I am trusting my HO2s currently.
                If it is doesn't corelate with the WB I will replace it.
                Not much tuning done at all, but this is what I have to work with.
                Quck initial test drive.
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                  why are you going full throttle on something you haven't hardly tuned?
                    Just that one test, just to see what I am up against lol,
                    since it was a stock 3500 running stock 3400 code, was hoping it would be a little closer.
                    As of April 2
                    Injectors: #36 GTPs
                    TB: 65mm TCE
                      So, except for not going WOT lol, any other tips.
                      Hope to get some time tomorrow for some tuning.
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                        Just starting my VE tune now, having problems with the Table Modifier though.
                        I follow the book, when I try to import my new VE table it fails because it is missing variables ?
                        Scan http://www.scandepot.net/viewscan.php?pk=5042
                        Original VE Table http://www.scandepot.net/viewscan.php?pk=5044
                        Modified VE Table from Table Modifier http://www.scandepot.net/viewscan.php?pk=5043
                        What am I doing wrong?
                        As of April 2
                        Injectors: #36 GTPs
                        TB: 65mm TCE
                          Ahhh, Set KPA range in table modifier
                          As of April 2
                          Injectors: #36 GTPs
                          TB: 65mm TCE
                            Rob,
                            What did you find out about your fuel pressure? The pressure should change with vacuum unless the spring is bottomed out. Can you adjust the pressure higher?
                            MinusOne - 3100 - 4T60E
                            '79 MGB - LZ9 - T5
                            http://www.tcemotorsports.com
                              It was acting really funny, but I knew my Fuel Filter was probably plugged as when I replaced the pump 2 weeks ago it was siezed on.
                              I had let it sit and soak and have finally replaced it.
                              Pressure does seem drop a very tiny bit with vacuum, but not much.
                              I have been busy at work and not had a chance to get to it again.
                              This one was the complete unit, what Base do you use? pre 2000 ? or newer?
                              I was thinking of getting a new 2000+ base (55psi) and try that.
                              As of April 2
                              Injectors: #36 GTPs
                              TB: 65mm TCE
