Elm327 or similar device
  • #31
    Hopefully your PCM isn't like my wife. If it is then it could have lost the keys...
    • #32
      Not exactly the samething but check out ebay auction #280455113434 Its a programer that I have never seen before and is pretty cheap. I wonder if it is worth a shit. I almost want to buy it just to see if it works at all. But I just hpt and don't really need it.
      Brent
      • #33
        My wife has just lost her mind lol.
        As for that programmer, I have seen them before, but it is KPW, we need
        J1850 VPW protocol.
        As of April 2
        Engine: 2006 SV6 3500 LX9
        Trans: 2002 Getrag F23 5speed
        Injectors: #36 GTPs
        TB: 65mm TCE
        Maf: 1999 3400 Montana.
        Beverages: Ice Cold CANADIAN.
        • #34
          So it wouldn't work on our cars at all? I ordered an elm 327 scanner off ebay hopefully it will be here next week so I can pull some codes on the old ladys aurora.
          • #35
            No that programmer will not work on our cars, mainly European.
            The Elm will get you your info though!
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
            • #36
              The worst part of mine loosing her primary keys is now she has the spare (our only one for now) and the keys have a keyfob built into them and aren't readily available like they are for my car...
              • #37
                Well, I have been successfully in writing the App to get Seed & Key!
                Also (though many have told me the ELM can't get the Osid) I can retrieve the OSID and Vin of the PCM!!!!
                Here is a SS
                Let me know if anyone wants to try it out!!!
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                • #38
                  i have no idea what OSID is, but i am interested...
                  i can use my ATX power supply and give the PCM 12 volts and go through what i think may be the correct set of hex digits...
                  may be able to get the OBD1.5 tuning ball rolling...
                  • #39
                    I think OSID is Operating System ID? I know it is the PCM ID
                    example = the OSIDs that DHP supports http://spreadsheets.google.com/pub?k...n1_K034oyJoMUQ
                    My OSID is 12221682 which is if you look at that chart from a 2001 3.4 Impala, which is what I got the PCM from.
                    I am inputing some different commands here and getting some interesting results.
                    The Elm327 doesnt do highspeed so thats next on my list, but I am going through some commands that a found in the HPTuners archive
                    Make sure key is on Position, engine off.. and enough battery power.
                    Disable normal message transmission on all nodes
                    Send: 6C FE F1 28 00
                    Rec: 6C F1 <active node> 68 00
                    Read Seed - Data Link Security Access
                    Send: 6C 10 F1 27 01
                    Rec: 6C F1 10 67 01 <2 byte Seed>
                    Send Key - Data Link Security Access
                    Send: 6C 10 F1 27 02 <2 byte Key>
                    Rec: 6C F1 10 67 02 <Sucess status?>
                    Request High Speed Mode From All Nodes
                    Send: 6C FE F1 A0
                    Rec: 6C F1 <active nodes> E0 AA
                    Begin High Speed Mode
                    Send: 6C FE F1 A1
                    Rec: 6C F1 <active node> EF
                    Scan Tool/Test Device is Present
                    6C FE F1 3F
                    <DOWNLOAD BOOT LOADER>
                    Request Upload
                    Send: 6C 10 F1 35 01 <2 byte size> <3 byte start address>
                    Rec: 6D F1 10 75 01 54 (Request Response)
                    Rec: <Data block>
                    Send: 6C 10 F1 76 00 54 (Block Transfer Response OK)
                    Repeat
                    Return to Normal Mode
                    Send: 6C FE F1 20
                    Rec: 6C F1 <active nodes> 60
                    Without HighSpeed I know I can not flash, but hoping to be able to dump the bin from PCM with the Elm327
                    Maybe dimented24x7 can chime in here
                    As of April 2
                    Injectors: #36 GTPs
                    TB: 65mm TCE
                    • #40
                      Uploaded at
                      Need to clean up code and comment then I will upload source as well.
                      As of April 2
                      Injectors: #36 GTPs
                      TB: 65mm TCE
                      • #41
                        looks like roughly the same command scheme as the OBD1 setup...
                        • #42
                          I just remembered I have a 95 Jimmy 4.3 Pcm and connectors at the shop somewhere.
                          That would be OBD1.5 ?
                          As of April 2
                          Injectors: #36 GTPs
                          TB: 65mm TCE
                          • #43
                            from my diagrams, it looks like it. looks like the only thing that's removeable from the PCM is the knock filter, which is the same way the 93-95 3100 and 94-95 LT1 are...
                            • #44
                              I'll go through my pile of stuff in shop this week, see if I can find it and see if I can communicate with it.
                              As of April 2
                              Injectors: #36 GTPs
                              TB: 65mm TCE
                              • #45
                                Hehe, well had a free hour this aft, so added a seach of .xls file to get Veh info cross referenced by OSID, and change the look of the Form a bit.
                                What do you think?
                                (will upload latest version later this evening)
                                As of April 2
                                Injectors: #36 GTPs
                                TB: 65mm TCE
