Hopefully your PCM isn't like my wife. If it is then it could have lost the keys...
Elm327 or similar device
My wife has just lost her mind lol.
As for that programmer, I have seen them before, but it is KPW, we need
J1850 VPW protocol.As of April 2
Engine: 2006 SV6 3500 LX9
Trans: 2002 Getrag F23 5speed
Injectors: #36 GTPs
TB: 65mm TCE
Maf: 1999 3400 Montana.
Beverages: Ice Cold CANADIAN.
No that programmer will not work on our cars, mainly European.
The Elm will get you your info though!As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
Injectors: #36 GTPs
TB: 65mm TCE
I think OSID is Operating System ID? I know it is the PCM ID
example = the OSIDs that DHP supports http://spreadsheets.google.com/pub?k...n1_K034oyJoMUQ
My OSID is 12221682 which is if you look at that chart from a 2001 3.4 Impala, which is what I got the PCM from.
I am inputing some different commands here and getting some interesting results.
The Elm327 doesnt do highspeed so thats next on my list, but I am going through some commands that a found in the HPTuners archive
Make sure key is on Position, engine off.. and enough battery power.
Disable normal message transmission on all nodes
Send: 6C FE F1 28 00
Rec: 6C F1 <active node> 68 00
Read Seed - Data Link Security Access
Send: 6C 10 F1 27 01
Rec: 6C F1 10 67 01 <2 byte Seed>
Send Key - Data Link Security Access
Send: 6C 10 F1 27 02 <2 byte Key>
Rec: 6C F1 10 67 02 <Sucess status?>
Request High Speed Mode From All Nodes
Send: 6C FE F1 A0
Rec: 6C F1 <active nodes> E0 AA
Begin High Speed Mode
Send: 6C FE F1 A1
Rec: 6C F1 <active node> EF
Scan Tool/Test Device is Present
6C FE F1 3F
<DOWNLOAD BOOT LOADER>
Request Upload
Send: 6C 10 F1 35 01 <2 byte size> <3 byte start address>
Rec: 6D F1 10 75 01 54 (Request Response)
Rec: <Data block>
Send: 6C 10 F1 76 00 54 (Block Transfer Response OK)
Repeat
Return to Normal Mode
Send: 6C FE F1 20
Rec: 6C F1 <active nodes> 60
Maybe dimented24x7 can chime in hereAs of April 2
Injectors: #36 GTPs
TB: 65mm TCE
Uploaded at
Need to clean up code and comment then I will upload source as well.As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
I just remembered I have a 95 Jimmy 4.3 Pcm and connectors at the shop somewhere.
That would be OBD1.5 ?As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
I'll go through my pile of stuff in shop this week, see if I can find it and see if I can communicate with it.As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
