Ok, so i have essencially a stock tune put back on my car. Timing and Fuel levels are basicly stock from what i understand. I do have 42.5lb Injectors and got a flow rate figure of "190" and from what ive seen doing a search that is pretty close to what everyone else runs (varries a little depending on fuel pressure).
LTFT at partial throttle is -15 to -20% and under boost its at -2 to 0%, so from what i understand my hard acceloration fuel trims are where they should be.. and WBO2 is 10:1 (will lean that out a little after i learn a little more, but atleast its safe for now) How do i now lean out my crusing speeds under partial throttle (say 10-40% throttle) while out of boost? is that done threw the VE table? partial throttle im seeing 10:1 AFR (no boost, 10-40% throttle).
Also on Decel (foot basicly off the accelorator) the WBO2 also runs 10:1, where would i need to start looking to lean out my Decel?
When Logging to tune fuel, what data should i include in the logging?
Sorry for the newb questions... still trying to learn/understand the tuning side, I read basic info about VE, PE, AE ect so i do kinda understand what they are... I don't have any logs as of yet.. I am trying to understand what each thing means as well as what i should be logging to get the correct info..
S
S
