What is Tiny Tuner? Well it's a new BIN file editor for OBDII 96-05 GM V6 equipped platforms. This editor also allows you to access more tables than the DHP or HPT editors. Plus this editor is open source. So if there are any programming nerds here who would like to fill in some more of the 60 V6 platform info. Please feel free to do so. Now this program will not flash a BIN to your PCM or scan from your PCM. It will only edit. You will still need your DHP or HPT equipment to flash and scan. More info in the links below on what this program can do.
http://www.clubgp.com/newforum/tm.as...mode=1&smode=1(Yes I know I should be shot and hung for posting a clubgp link
http://theblattners.com/Projects/TinyTuner/default.html(Download links provided at bottom of page)
