AE enrichment?
  • #16
    well i broke out the meter and ohm'ed them out.
    cold it was 5.6-5.8k and i checked them when i got back prob a 30 min ride and the were at 6-6.1.
    i also checked the ones i took off that were giving me WOT/under load problems and they gave me the same cold readings. out of the 3 sets i tested i got pretty much the same cold numbers.
    checked the MSD ones i got and they were 7-7.15k cold. all the coils came up with about the same numbers.
    im gonna check the icm's. i would like to know whats defective with the virtually new parts i had.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • #17
      I got 5.8 to 6 on mine. Car is pulling without hesitation now, but still have the stumble in the idle. I am getting convinced that the IAC is out of wack with the other sensor it works with. I cannot remember what it references for the life of me, but I do know they can get out of sync, and cause this problem. I had this happen a couple of years ago and having the IAC reset fixed it. Im going to spend the dam 30 bucks and have it done. Ill post up the results.
