I'm tired of having this stupid Contour in my drive. It's making my truck look bad because they are both Fords, and this thing is still sitting here. I ran a scan at idle in my garage both unloaded and loaded (a/c on, lights on, high beams on, in D, hazards on, brakes lights on, turned the steering wheel back and forth). Tell me what this stupid scan of it is telling me... pretty please
Now, before you say anything about the TPS reading 20%, I did change it out last summer, but the new one read the same. It also read 0% when unhooked so the wire is ok. I don't know why, but Ford has it set up so there is tension on it from the throttle when bolted down, it's not set up to read 0% when you're not touching the gas. I do remember my friend having to set his TPS at .7v way back when, but that was in the days right after OBD-2 came out, and his car was not OBD-2, so I thought maybe it's this strange thing Ford did that carried over. My scan tool is one of the generic ELM-327 version 1.2a that I got on ebay that was sent over from Hong Kong (paid $5, plus $20 shipping). I am using ProScan v5.4 because if I run 5.6, it says that my adapter is not a genuine compatible scan interface, so 5.4 it is. Give me some thoughts of this scan if you would, kind sirs. TYIA.
