28 degrees @ WOT, nice! You run premium fuel?
Need tuning help with my cam.
Brian
3400 SFI V6, 4T60e
Nope that was a mix of 1/4 tank 87 and about 4 gallons of 899.15:1 compression FTW!
Originally posted by sprucegagt View PostWhy?
not saying he has to run them at 55 or 43.5. its his car he can do whatever he wants.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
I think he was saying that to get them to be 33 lb/hr you run them at 43.5psi, and not the 55 that they are rated at 36#. Or you could just tune it as is at 55psi at 36#.sigpicNew 2010 project (click image)
That calculator backs that up... close at least... 37.1lb/hr
Is that calculation wrong?Last edited by 3400-95-Modified; 09-23-2008, 11:43 AM.
Originally posted by SappySE107 View Post33# at 43 psi = 36# at 55 psi? What kind of fucked up math does that require to be true.
like i said its his car he can run them at whatever psi he wants to
if you do it the other way around going from 55 psi to 43.5 psi and start out with 36 as the old flow rate you get different numbers and you end up with the 33lbs at 43.5
but going from 43 to 55 you get the 37lbs
99 Grand Am GT
Originally posted by geldartb View Postif he leaves the pressure at 55 then they wont be 33lbs anymore they will be the 36lbs like they are in the grand prix, yourr only getting the 33lbs cause you would be running them at 43.5psi
I'm also thinking that higher pressure will get you slightly better fuel atomization. But that's my own theory.Your local OBDII moderator
2000 Grand Am GT w/ WOT parts
Yeah I'm not sure what the flow vs pressure formula is, but its an odd ball one.
