ok well today i got it to idle and run for an extended period of time but its still sitting rich.
i have a bunch of scans from today and the bin file for the car im posting up. so here i am to pick the tuning guru's brains for some area that i have overlooked.
i got a bunch of small scans mostly when i was trying to find a good idle.
on a positive note the noise is subsiding and it didnt foul the plugs.
its running rich and runs rouch(ie not assoc with the roughness of the cam)
specs of the car
1357 cam from wot-tech detailed specs for cam
INT 230 EXH 236 @.050
112 LSA
515 INT 515 EXH lift at 1.6.1
ported 3400 upper and lower
65mm throttlebody
28lb series 1 3800 injectors
specs of the car
112 LSA
65mm throttlebody
