Hello,
I was wondering, is the "Engine Service soon" light the same as a check engine light on GM products? I'm dealing with a car that has this light on and I'm not sure if I need to try and pull codes or what? Lastly, can you pull trouble codes by using a jumper or do you need a scanner? Thanks!
Regards,
Tee
Regards,
Tee
