How in the hell do you determine which definition you need for your ECU... That's my first question. The next is the GM OBDI datastream definitions, once again, how do you know what you need?
I'm asking for two instances... my 1990 Beretta Indy will need to be tuned when I start tweaking so I need to know what to expect. Prom is AUPC 2004, The other instance is a friend who is trying to get a chip burned for his 1990 Beretta GT and every one that's been made wont even run the car... I'm wondering if the wrong definition is being used when burning which may or may not be changing the pin out functions.
