I will have to get a copy of it posted when I get on my other PC.
I have a question about the difference between these two tables:
COLD ENGINE TEMP. DEPENDENT AIR/FUEL RATIO
AFR VS COOLANT TEMP FOR COLD ENGINE AND CLOSED THROTTLE
I want to make sure I am understanding this correctly.
--> Is this for when the throttle is not being pressed, so the engine uses this AFR to idle?
--> Is this for open loop only? Or does closed loop also read this table?
--> Is this for when the engine is still in open loop? And used when not at idle? Like when the driver is pressing the throttle?
I know closed loop uses the O2 sensor feedback.
Is the scaler number sitting at 14.7 for Stoich AFR the one that the O2 sensor uses to adjust and maintain the closed loop AFR?
The Main Spark Table, this is always used in both open and closed loop?
I see tables and I have an idea now about how to tune it, however I would like to understand more about how the computer uses them and when.
When I know more about how/when its used, I can learn better how to tune them.
When I know more about the behavior of the engine as a whole, I can use my data logger and have a better understanding of how to tune this for good response and power.
One thing I noticed, When I adjusted my bin file previously, I noticed it doesn't build boost as fast, where as before, the engine used to build boost faster at lower RPM.
What is the best way to tune the AFR and spark so that it builds boost quickly for the most response and power?
I know at WOT it does built up to my max setting which is around 13 PSI, however I can tell, the acceleration is a bit slower off the line because of the longer delay in building boost.
I used to be able to give it half throttle and it was up to 13 PSI within 1-2 seconds, now it takes about 3-5 seconds.
EDIT:
Also, I am slowly figuring out how to adjust the wire pins for my AC and stuff to work.
I have a few questions about making the TCC work.
The Beretta wiring harness originally only looked for 2 gear inputs from the 3T40 before it allowed the TCC to engage, those were 2nd and 3rd gear.
The TGP EPROM, it looked for gear inputs 2nd, 3rd, 4th gear from the 4T60 transmission.
I wired the 3rd and 4th gear signals into the Beretta 2nd and 3rd gear harness inputs.
Can I somehow disable the TGP 2nd gear input and bypass it, this way it sees 3rd and 4th gear only, then locks up the TCC based on load and speed?
Or do I have to somehow figure out how to add a 2nd gear input to this ECM as well?
Is it possible for the TCC code to be set to ignore the gear inputs and only work based on mph, throttle angle, and engine load?
I know when GM released the 2.8L V6 in the 1988 Beretta, they did this, the TCC engaged correctly without the use of transmission gear selection feedback.
EDIT:
