Ok, here's my problem with background info. Sorry in advance for my complete ignorance on OB1 tuning.
One of my 2 $700 TGP purchases has a different turbo on it. No luck identifying what turbo, but it's making more boost than stock. Much faster than my stock TGP. Since hooking up the wastegate the PO never attached, I've never had the ECM hit the boost limit on the street. But I went to the dragstrip last night, and the car is hitting the ECM's boost limit around the 1000 ft mark limit which cuts the engine fully for about a second and sets an overboost DTC. Car could only go 15.4 @ 80mph. It was doing 90mph by the 1000 ft mark, but was slowing down after that from the factory tune shutting the fun down. I think the car should be good for mid 14s in current setup if I can get the stock boost limit raised. I don't think I need to raise it much.
I have a Moates APU1 and running Tunerpro v5. I claim complete ignorance over this program. To me, DHP on OBD2 seems easy and straightforward to use, but I really don't understand what all this xdf adx ads 8F$ file stuff is, and unlike DHP bins I've tuned, most of the parameter tables are difficult to comprehend. Eventually I'd like to figure this all out and datalog and tune properly, but all I want to do at this time is raise the stock boost limit a couple psi so I can burn a chip and see what this junk will run in current state. Pic below is what I'm looking at as far as boost tables. I haven't a clue what needs changed to raise the boost limit. Any help is appreciated.
