I was just curious if anyone had tried using the KCOOLVLT settings in $A1 as a nitrous window switch...  Seems to me if you wired the TPS signal to C14 and set KCOOLVLT to ~4.9V and KCLTMRLM to 0 you could use it to trigger an armed nitrous system.  Or any other system you want triggered at WOT.
Is it safe to divide the TPS signal wire to two ECM inputs?
