I am leaning out to over 13 AFR above 5000 RPMs.
I have a new (last year) high flow TRE fuel pump. It is hot wired to get its own power circuit from the battery for minimal voltage drop.
That goes to an aeromotive FPR (http://aeromotiveinc.com/products-pa...ass-regulator/).
Then I run return-less to stock 3500 fuel rail and injectors.
I have a mechanical guage on the regulator and it stays solid when revved but I cant watch it when driving.
Fuel filter is about a year old.
I kept increasing fuel by PE table and VE table but was getting diminishing returns in upper RPMs.
Here is a datalog run up to 5000. Above 5000 it just gets leaner. WOT is on pg 6.
Whats most likely going on? Is the "final BPW" the ACTUAL BPW of the injector, or a calculation? From the data it looks like no matter how long it opens, no extra fuel is being delivered.
This makes me think the fuel pump is not up to the task, but that seems weird as the pump is new, works, and is rated way higher.
Also, this is not a new problem, I just haven't been driving up in high RPM range to discover this.
Update: problem fixed, pg 3 for solution
