I've been having a problem with a collapsed lifter and this issue popped up over the last year or so that I haven't been driving the car.
After I started to develop a ticking lifter, I changed to 36# injectors. I previously had 30# in there. I don't recall my thought process at the time, but it seemed like I was running out of fuel up top and thought I'd try switching to 36s.
Now the car will start up, idle ok for a few seconds (AFR ~15) then it goes off the chart rich (as in barely running). Originally I was running $8F, I tried changing the BPC vs EGR to the correct number based on the new injectors, and it just runs super rich. Changing BPW does nothing, forcing open loop did nothing, and I do have the EGR disabled in the code.
I also decided I'd give Code59 a try since I was annoyed at $8F and my damn shift light. It also seemed like $59 might have more potential for a manual trans car. Got a 3 bar map, picked one of the 60degree bins to start, and changed BPC. Bottom line the same thing occurs. It starts ok, then goes pig rich.
36# on a 2.8 seems a bit high, but not unreasonable. I'm having trouble understanding why BPC is having no effect in either code. No error codes are being thrown.
Anyone have any ideas?
Sorry if this seems jumbled, trying to throw it together on my lunch break
