I was logging the other day and took the engine to about 6800 rpm, and noticed in the log that the "Engine Speed" value stops increasing at 6375 rpm, and the "Engine Speed x 50" value starts increasing in 100 rpm increments after 6400. I'm thinking this is a bug? I can't see anything obvious in the datastream definition that prevents showing values above 6375.
nAst1: Progress and Concepts Thread
should be 50RPM increments.... i'll verify it on the bench if i can, i should probably retain logs of when i do bench runs for reasons like this.
engine speed is supposed to stop at 6375RPM since that's the limit of an 8 bit variable with a multiplier of 25 (i.e. 255* 25 = 6375)
but engine speed X 50 should still be in increments of 50, not 100, regardless of RPM.
Originally posted by caffeine View PostInteresting thing I just discovered; the fuel-cut 2-step still builds boost for me set at 2400 rpm, but only 2-3 psi. Makes me wonder how much spark cut would build.
Sent from my HTC One X using Tapatalk 2-60v6's 2nd Jon M.
Originally posted by pocket-rocket View PostOr a customizable spark retard under 2 step
i think ideal would be constant fuel delivery with spark being cut above a certain RPM threshold, but with a bit of a twist... near the cut threshold, instead of a total spark cut, significantly reduced timing(so that the engine won't easily accelerate past the cut threshold and cut/deliver/cut/deliver, probably have to fire ATDC) so that a constant stream of high heat exhaust gasses will get to the turbine. it would be absolute hell on the exhaust valves, but you would have the full air/fuel charge and the ignition necessary to fire it off powering the turbine.
I'm sure the cars with functional cats would prefer retarded timing vs full spark cut under a two step that retains fuel delivery. At that point it would double as anti-lag for boosted cars.
Originally posted by Mars View PostIs this stuff ready to use ? Can I try it on my setup or are you guys still in the testing phases ? Sorry don't feel like reading 40 pages...
on the spark retard 2 step, one of the guys on PFF wired a switched ground into his IAT sensor, and then commanded way reduced timing when the IAT saw ground.
work in this case? I don't know, but it's a easy button for sure.
this has me tempted to go OBD1 now... I like the idea of having tables that cover my RPM ranges."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by robertisaar View Postdoing that is one hell of a hack method.... lying to the ECM about the air temp will cause all sorts of unintended consequences. i did add in a table that allows for different amounts of advance based on IAT(or IRT, if selected), but that's not how it's intended to be used."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
i think i gave out the info i used to make my initial version and that was used by bl85c(???) to patch into 6E or code59, i forget.... anyways, i see how he did it, not very different than what i did, in fact, he may have solved my inconsistency issue.
here is the code i saw:
Code:; ; Disable EST ; D722: CMPB LC500 ; Compare to RPM for Disable EST D725: BLO LD74A ; Branch if Lower D727: CLRA D728: CLRB D729: STD L3FDC ; SPK Dwell period cnt'r D72C: JSR LF4EE ; SHORT DELAY D72F: STD L3FE6 ; SPK Dwell Cnt'r D732: JSR LF4EE ; SHORT DELAY D735: STD L3FE8 ; CURRENT EST FALL-LAST EST FALL D738: JSR LF4EE ; SHORT DELAY D73B: STD L3FF6 ; EST FALL CNT'R D73E: JSR LF4EE ; SHORT DELAY D741: LDX L3FEC ; B Cnt'r last ref D744: JSR LF4EE ; SHORT DELAY D747: STX L3FE4 ; B Cnt'r Bgn nxt Dwell D74A: RTS
