i can put those kind of values into my bench to test it, but it can handle really high PPM values...
BFBD (91-92 3.1 W-body calibration) is 40,000 PPM. with the FWD stuff, final drive ratio doesn't actually change PPM either.
the only real limitation to the VSS stuff is that the pulse divider setup for making the 4K PPM signal works best when dealing with increments of 4K PPM. the highest value you can use the divisor with technically, is 44,000 PPM, since it can do a /11 operation to make the 4000 PPM signal. if you go beyond that, then you'll need to "condition" the signal either before it gets to the ECM or between the ECM and the cluster.
