nAst1: Progress and Concepts Thread
  • cell 0 is idle cell, what kind of thermostat are you running, since there is a BLM enable coolant temp qualifier.
    the 1.05 bins (they are the latest i've released, BTW) should have single-fire disable completely already, so i'm not sure what you did to "disable" it other than possibly making the qualifications to get into it even more difficult/impossible to get into.
    there is a flag for TCC lock to enable highway spark called "TCC Lock Required for Highway Spark Advance" disable that, if it isn't already.
    the temporary lack of rev-down in DFCO is usually caused by IAC logic. next time you look at a log that has it happening, you'll likely see that the IAC quits moving downward for a short amount of time before continuing to drop. there are settings to mess with this to match it to your liking, but i can't remember what they are off-hand.
    • You should add a permanent link in your signature for the latest file downloads..
      I may actually make the switch this year since I'm not entirely happy with the Holley 950.
      • Originally posted by Superdave View Post
        EXCELLENT idea. i'll just link to the post that i have release notes/ZIP in. i have a hard time finding the files myself and i upload the damn things
        EDIT: done. now i'll just have to remember to update the link when i post updates.
        speaking of: working out a few bugs on my bench, when i have that done, the first revision of the 3BAR code will be posted assuming it is 100% functional. for this version, boost fueling will be done only through the above 100kPa fuel multiplier table and boost spark will be done only through the boost spark retard table. this is only due to me trying to get this out as soon as possible, since my last release was in october. i don't think it will take long to get the next version out, the one that will convert the 3 total VE and 3 total main spark tables into 4 total VE and 4 total main spark tables, 2 each for N/A and 2 each for boost. at that time the boost BPW multiplier will still be present and adjustable for rough fueling correction, but the boost spark retard table will be removed since it will be unnecessary.
        • Originally posted by robertisaar View Post
          Ok I'll check the iac stuff next. I did manage to get highway cruising working. Turns out I had converter over temp spark disabled by maxing out the min coolant temp to enable.
          As for the idle BLM being locked at 128, I am running the stock 195* thermostat and a heated O2 sensor. I tried enabling the idle VE tables and found I could no longer rev up my engine after idling when warm so I disabled it again. Enabling the idle VE table made no difference as to the 128 BLM.
          Another question: I can't seem to get my low MAP VE cells to get any leaner than 122 or so. Is it possible that my injectors are already squirting as little fuel as possible since I'm running the stock 24# injectors at a constant 55 psi (vette fuel filter/regulator)?
          '86 Fiero, 3500, 4-speed
          • post/send an XDL and current BIN, i want to see what's causing issues here.
              LX9 highway cruise enabled.bin LX9 logs.zip
              Here is my latest .bin and a couple logs. I think the one labelled "crap idle" is the one where I temporarily enabled the idle VE table.
              • interesting.
                i notice when you're at an idle, you're REALLY close to being at the BPW limit to allow BLM updates at idle, and a lot of the times, you go under it.
                do a search for these and cut them in half(EDIT: maybe even a little more than half, since you idle near .6mSec when fully warmed):
                Low BPW Threshold Required to BLM Learn in Idle Cell (KLCBPWIL)
                High BPW Threshold Required to BLM Learn in Idle Cell (KLCBPWIH)
                Low BPW Threshold Required to BLM Learn in non-Idle Cell (KLCBPWL)
                High BPW Threshold Required to BLM Learn in non-Idle Cell (KLCBPWH)
                otherwise, when you're in the correct conditions to allow BLM updates, it looks like they happen, when necessary.
                • Thanks I'll try that tonight
                  • Ok I gave that a shot, it didn't change the BLM not updating and once in a while I also now stall while idling. I also have this issue where when I'm coasting in neutral down a hill the engine will rev itself up and down constantly until I either put it in gear or come to a stop (only does this sometimes, happens more often at higher speeds). I'm assuming this is IAC related?
                    • revving up and down is the ECM trying to control idle speed. your IAC counts and spark advance are probably swinging at the same rate if i had to guess, since both spark and IAC are modified to control idle speed. there is too much correction happening too fast, so the engine speed is overshooting the target. to tone this down, you would need to change the idle spark correction to be less aggressive, change the IAC PID tables to be less agressive, or make it harder to get into the conditions that will allow engine speed to attempt to match target idle speed when moving.
                      quite a few options there. and hard to tell which will work best for your application too. even GM seemed to have issues with this.
                      i really don't know why BLM isn't updating then... as long as INT is far enough away from 128 for a sufficient amount of time, then BLM is supposed to move. for some reason, it's getting reset to 128 constantly, and only at idle from the sounds of it... i wonder if it's BLM cell 0 related then.
                      • not much of an "update", but i have been eyeing this....
                        Chips and Sockets RMA: Repairs & Returns Software List All Products (100+) Cables USB/Emulation/PC Browse by Vehicle WideBand Products Ford 1986-2004 GM 1985-1995 Nissan 1986-1995 Honda/Acura 1988-1995 Driver Download Browse Products Datalog and Reflash Realtime Emulation Chip Programming
                        from what i understand and have read so far, the normal mode 4 command response was modified so that now mode 4 commands basically are bytes that are written to the NVRAM module. the module is mapped from $2000-$2FFF, which is convenient considering that the 9396 SRAM area ends at $1FFF. probably not a coincidence either.
                        with the patching MCS did to his BINs, he came out with this:
                        1 byte write $FF starting at $2000: F4-5A-04-01-20-00-FF-8E
                        2 byte write $BE $EF starting at $2000: F4-5B-04-02-20-00-BE-EF-DE
                        up to 8 bytes can be written at one time. seems simple enough. and from a quote:
                        Originally posted by MonteCarSlow
                        I have working DOS utilities that can be used to upload and download bins to and from the ECM via ALDL. An upload takes about 25 seconds, and a complete download of the bin takes about 50.
                        so from the sounds of it, it ALMOST allows emulation...... just not emulation of the entire PROM, just 4KB of it. for $45, it probably isn't a bad option, and from what i understand a windows GUI was released as well, but........
                        is it worth the time to understand and support it? the patch he made for $8D seems REALLY, REALLY simple and would probably take no time at all to impliment and probably still retain normal mode 4 commands, but 4KB.... that's 14 17X17 tables.... or any random combination of stuff so long as it takes up 4096 bytes or less.
                        and here's the biggest thing: IF they were to be used, 7730 and 7727 could be used as well instead of only the 9396, BUT it would absolutely require everyone running nAst1 versions that use the extra RAM to use one of these modules, whether they're "emulating" or not... and the NVSRAM module seems to have it's own battery in it, which is supposed to last 10 years.... i have to wonder what would happen after the 10 years are up. would it still work like normal RAM and just lose it's battery-backed capability? will it outright fail? will there still be replacement NVSRAM modules that can be plugged in 10 years from now? 20 years? and does it interfere with the 9396's existing 2KB added RAM?
                        all of these are questions that make me want to stay away from it. of course, i could probably ask MCS and get most of these answers, but i'd rather not bother him if i don't need to.
                        do i need to?
                        • Thats pretty sweet. I like the price point of it, but with being new to tuning the hit tracing helps me see where the ECM is reading and makes the ostrich worth it for me.
                          Sent from my Sony Tablet S using Tapatalk 2
                          • I'll stick with my Ostrich. 5 second upload of the whole bin.. full emulation... worth every penny to me.
                            • true enough.... i may keep it in the back of my mind then, in case i somehow manage to fill up the 2KB of extra RAM already present.
                              or maybe..... and this would probably be a gigantic PITA for me, release 2 versions of every BIN, one intended for a 9396, the other intended for a 7727/7730 with the add on module?
                              or....... maybe i can figure out a way to remap the RAM to be in the 1000-1FFF range instead of the 2000-2FFF range.... then only one BIN would be necessary for any 7727/7730 or 9396 ECM.
                              • I'm playing around with the tune for my 3900 using the 9396 pcm and am trying to slow the rpm drop between shifts. I see a throttle follower offset in the scalers and maximum follower steps vs rpm in the tables. Will either of these do what I'm looking for? It's a fiero transmission and the shifts are far from fast so it's really something I would like to address. Thanks.
