I am a HD mechanic, class eight engines mainly, my problem is I have a 4.3 in a 1992 Jimmy. After running it will just shut down, I did a tune up and changed the coil.
We took it for a drive and it shut down again put it in the shop and it gets no fuel, and has no ignition. Leave it cool for an hour and it will start, the run times are getting shorter all the time. I read the wiring diagrams and the only thing that controls both is the PCM. The local auto wrecker had a PCM. The original is a 16144288, the new one is a 16156647, to me it is quite a lot different, Do not want to install it and damage other stuff. The truck is a winter driver for a friend who runs the snow plow.
Advise is required
Advise is required
