I've been searching and searching and can't find a straight answer to this question. Do I need to repin anything to go from A1 mask to 8F with a 1227730 in a J-body? I think the stock TGPs used different connectors and wiring only because of the underhood 1227727 ecm. Also, do I need to change the memcal to go with 8F? If I can switch to 8F with just a 2-bar MAP sensor and a PROM (that I have burned myself) then life is stupendous! Please tell me it is so
Because I know you're gonna ask, I'm putting a Holset HX35 on a just-broken-in GM Goodwrench 3.1 LHO with a Melling MTC-5 cam (204/214 @ .050"). Super-sleeper 94 Cavalier RS grandma car!!
BTW, you guys seem to have an awesome forum with lots of helpful members, which is why I joined.
