specifically looking for two of them: 94-95 LQ1 and 95 3100...
now, according to
the 91-93 and 94-95 LQ1 injectors should flow the same. i look at a factory $DF file and see 22.5lb/hr and then look at my newly almost finished $2E file and see 20.5.... now, i'm fairly certain the 2E file is correct, or at least closer, since it does agree with said chart, so it's likely the conversion is off in the DF XDF. but i'd like to know where the 21 lb/hr number came from.
also: similar situation with a $1FA BIN i have: it is saying the 94-95 3100(MAF anyway) has 17.46 lb/hr injectors... i'm also confident in this equation. the chart says 19, but i have no idea where this number came from. i've heard both before, but am not sure which to believe....
and yes, what you're thinking that i'm doing, it's in the works... it should be good up until ~350HP on a 3100....
now, according to
