$8D - Anyone Else Using It?
  • #16
    I see in that thread it mentions boost, and from what I gather someone modified 8D much like people modified a bin to make code 59?? So this is modified 8D code we are talking about correct?
    What is your setup exactly? Just because one bin idles better stock than another doesn't make one less desireable. It just means the one that idled better happened to have tables with VE stock that was closer to your modified motor. Tuned both would perform the same...
    Yes, we are talking about a modified version of $8D (S_AUJP V4) but not for boost.
    I've got a 3.1 with a 2000+ top end, Delta cams 260 regrind, 60 mm throttle body and headers with 1.5", 36" long primaries.
    The point I was trying to make was in response to the comment that $A1 was better because $8D never had factory v6 bins. All I'm saying is that isn't necessarily the case. Because of how well this code is documented and the amount of information available for modifying it, it's possible that a good tune would be easier to achieve with $8D. It's worth a shot...this is just a hobby for me so learning new things is fun.
    -- Scott
    • #17
      i never said it was better, just that for most people, it's already set up and ready to go.
      as far as 8DB(oost), is that out of the beta stages yet? last i looked into it, it still was.
      • #18
        correct, but A1 is meant for DIS motors, while 8D is meant for a ECU controlled dizzy...
        59 is also meant for a distributor, but can be modified to work with DIS.
        I'm running DIS on my set-up. All you have to change are 3 constants to get $8D to work with DIS.
        Just to be clear, I don't think there isn't anything wrong $A1.
        -- Scott
        • #19
          S_AUJP is not set up for boost. You're thinking about another version of $8D.
          • #20
            did you have to make any pinout changes on the ecm?
            • #21
              I didn't make any pinout changes. I'm running a 7727. Honestly, I had 20 minutes on Sunday to play with this. I stuff 4 cars into my 3 car garage during the winter so my toy is wedged between bays. I quickly burned the code onto the chip and started it right where it sat. Let it run until the fumes started to get to me. I did take a quick log and all the sensors seemed to be recognized. It did get into closed loop which is a good sign. I'll have more time to play with it Thursday evening so I'll know more then.
              • #22
                I took my car out for a ride this afternoon with the 8D code finally. I'm really slow. :-) It definitely needs to be tuned and I've got an idle surge issue to work on but all things considered it didn't do too bad.
                Just to close this out, I did the following to configure 8D for my 3.1 hybrid using DIS:
                Set the "Number of Cylinders" from 0 to 192
                Set the "SPARK ADV Initial" from 6.0 to 60
                Set the "SPARK ADV Max" from 41.84 to -10
                Set the "SPARK RET, Max for Knock" from -3.87 to -70
                Set the "Cylinder Volume" from 713 to 515.69 (for the 3.1)
                Set the "ERROR QUAL 41, Cylinder Select" from 0 to 08
                Left the "Injector Flow Rate" at 22.08
                Set the "VSS, Vehicle Speed Sensor Pulses" to the correct value for my setup (27106)
                Set the "MANUAL OPTION" to 1
                I checked the pinouts of my 7727 against a diagram for a 92 7730 V8 TPI L98 (which 8D was used in) with a cross reference to the "Ludis" page and didn't find any discrepancies. So no wiring changes needed for me at least. I have done a conversion from a carb'ed motor original to my "B" to the 3.1 FI motor so I'm only using the necessary engine sensors and nothing else. Everything checked out today...I was wondering about the VSS but it read fine.
                -- Scott
                • #23
                  What cr are you running? Any progress on the tune?
                  • #24
                    Sorry for the delay in getting back to you. I'm running about 9.4:1 with my hybrid I believe. No progress to speak of since it's been so cold and salty here. When we get a little rain and the roads don't have any salt on them, I'll be back at it.
                    -- Scott
                    • #25
                      Some guy(s) at v6z24.com are running this with good results so far with idling at least. Actually a hacked version with added features IIRC.
                      • #26
                        probably Super AUJP... can't remember what was added to it.
                        • #27
                          Yup
                          This past week I've been tooling around with a new "project". Jealous of all the hacks, and optional modes of other .bins; including launch mode to OBTAIN traction, not make smoke like A1 code...I decided to try a little something...Running 350 TPI code on a DIS motor. It's been done before...
                          A quick list of changes:
                          Selectable sensor WB
                          Extended VE tables (Rbob & Z69 versions)
                          PW limiter corrected
                          Extended PE table & selectable use
                          VSS retard table (Launch ) selectable use
                          8K RPM
                          Knock light (selectable Knock, PE, AE TPS,AE MAP light)
                          MT/AT selection
                          Shift light (generic operation currently)
                          Lock BLM in PE selectable now
                          Idle spark table selectable now
                          ALDL status of AE map, AE TPS, PE actions, Calculated VE, others
                          F11, B3, E10 reads added to code and ALDL options
                          Open loop Idle selection/setting if desired
                          • #28
                            Super AUJP is what I'm using as well. Supposedly the launch timing retard isn't working...at least that's what the person who originally posted this particular update said.
                            -- Scott
                            • #29
                              -- Scott
                              works in DF and A1!
                              • #30
                                How did this work for you? I have a 3500 that I have tried different codes on s ajup, nA$t1and $a1 with different results. Most of the time I get odd timing like 17- 24 degrees in tuner pro. I verified this with a timing light.
