Tuning a 93 3.4 Firebird
  • stock 3.4 auto idles at 1000rpm. Kinda high IMO for a 109 LSA cam (stock).
    Brought the idle to 800 and the stock cam loped nice (specially when I threw a little extra fuel in ROFL).
    • Originally posted by ForcedFirebird View Post
      i can't imagine what this cam would do if i could lower the idle rpms without it stalling.... muwahah.... can we do it?
      93 Firebird 3.4
      • Originally posted by robertisaar View Post
        thanks robert
        93 Firebird 3.4
        • Originally posted by tkoforpresident View Post
          eventually... when you figure out whats causing the stalling anyways...
          • well then tell john to kit it into high gear so i can start datalogging =P
            93 Firebird 3.4
            • Well, you know the situation max One of the connectors I gad won't hold the pin correctly and can push out when inserting it to the ECM. I had one the same way when I did Pauls car, but bought 2 sets of 7727 connectors when I did his and then another. Same pin on the orange connector won't stay, so I ordered 2 more (just in case).
              • I know, I'm just more anxious than ever to take a look at some data logs and try to get my car running right. This stuff is kinda fun. Then again, I do have all winter to get my tune right so there's really no rush i guess.
                93 Firebird 3.4
                • even though you can't tune it, you can log with the 1.5 ECM in there...
                    i don't know the .ads for my pcm
                    93 Firebird 3.4
                    • i made the ones for the 94-95 3.4OHV not too long ago, i'm sure they are similar to the 93...
                      • ADS is done, i'll post it here, and send it to Mark for TP...
                        EDIT: something interesting: according to the DS for it, the 24X sensor is completely ignored above ~2000RPM...
                          Uh, yeah. The 24x signal is only for low-rpm resolution to basically help make the idle smoother.
                          • i had a thought going, but realized the flaw in it, so i didn't continue past that statement...
                            • thanks for the .ads robert.
                              I also didnt' want to datalog until i get the new pcm in because i was going to start data logging with the tune (as small as it is) that i've been working on. It's such a rough idle (and super rich), i hate to start it and keep it running for long if i can help it.
                              So i figured i'd wait til i got the new pcm and new tune on it before i datalogged.
                              Any opposition or thougths?
                              93 Firebird 3.4
                              • i just put it up in case you should want/need it, and i know other people out there will use it as well.
                                i really don't want to count the number of ADS/ADX that mark has put on the TP downloads page that were made by me....
