if i get a prom programmer-how hard is it to learn
  • if i get a prom programmer-how hard is it to learn
    im strongly considering getting a PROM programmer so i can start learning how to adjust values to accommodate for boost, headers, etc... if i get this one:
    Transtronics shopping main page - industrial control Panel meters eprom programmers PLCs
    ill be spending nearly $300 but the compatibility looks very nice, how hard is it to learn to modify the code for boost-aftermarket parts-or for better mpg, is it just a matter a tinkering around with the pulse width & spark advance until you feel comfortable with it or?
    id just hate to drop $300 and have this thing sit around unused because i didnt make an informed decision as to whether or not i could learn to tune it in a decent time frame.
    Have you looked at Moates www.moates.net ?
    The four or five people I know swear by their stuff.
      no i really have no idea what would be my best option as far as one of these goes considering im looking to use the tgp code & work with 90-93 (or 91-93) luminas/berettas/corsicas/cav's with 3.1
      moates seems to be very import/ford oriented & if im going to use a gm ecm that concerns me as to compatibility-that concern may be invalid though.
        Import oriented?
        Super Dave, Rodney and Chris Wilson are three guys I know using it.
        And the J-Body guys love it.
        My car is running on a Moates chip.
          Go back to the website and READ the content. Don't just skim.
          Shop by Vehicle type:
          Click on the vehicle type for which you'd like to browse what we have to offer.
          - Ford Pre-2005
          - GM OBD1 Pre-1996
          - GM OBD2 1996-Present
          - Honda/Acura PreOBD2
          - Nissan
          Man 2 out of 5 are GM... Thats a pretty good ratio...
            looking around a little further-i found this
            USB Chip Programmer works with the AT29C256, 27SF512, and AM29F040 chips. Self-powered from the USB port, so no power adapter is needed! Burner can also be used to read stock GM memcals using the HDR1 adapter. While it will only program the three types of chips listed, please note that those three chips can be used as drop-in replacements for most EFI applications. Comes with stand-alone chip programming software (available for download). Also compatible with TunerPro RT. Will read most stock-style chips (2732A, 27C128/256/512/etc). Mini-USB cable is included.
            & this
            This is for any pre-1995 (OBD1) GM vehicle. Everything except the 1995 LT1. You should be able to datalog all of them, and reflash the 94 LT1 as well. Comes with XtremeALDL and NewCABL1 (RJ45/Moates-specific new style). There's a switch on the side which allows you to select 10k (across pins A&B of ALDL) or 'Open' mode. You use the 10k mode for older TBI and TPI setups, and the 'Open' for newer Speed density and LT1 stuff. This item can be used with TunerPro RT, TTS Datamaster, TunerCat reflash for LT1, WinALDL, and EFI Live V4(OBD1).
            if i get both of these will this (and software/prom chips) be all ill need to log/program the obd1 gm proms?
            i pulled up all of their products at once & i was just seeing tons of "honda, acura, ford, nissan, etc..." but looking further into it i found the GM listings.
              I'd recommend getting this kit too:
              This package is very popular. It comes with two 27SF512 chips, an 'S2' ZIF socket, and a G1 adapter! This is everything you need for TPI/etc chip adaptation. If you want different chips or different socket, just purchase the pieces separately from the other items listed.
                when i first went there i thought shop by vehicle was just a heading & there was nothing under it like with list all products, so i had no idea.
                as soon as i clicked that it was facepalm like a mofo!
                may i ask why you recommend that?
                    How hard is it to learn?
                    Depends on how many questions you ask.. and we all know you're good for plenty of those
                    Moates = the best.
                      I've got a few Moates stickers
                        i've got like a 12" and 6" somewhere... and a pen, and a post-it note thing too... i'm a free stuff whore, i know.
                        moates IS king shit when it comes to DIY tuning, its tough to beat their prices/service.
                        and using the burn2 makes it stupid-simple to burn a chip, the software for it(and the integrated screen in TP) calculates all of the offsets and shit for you. basically, choose which chip you're running; hit load file to buffer; program chip; done, unless you verify after every burn(which i do)...
                        and it looks like brad added in my opinions of tuning into the doc. thats just the very basics still, but you catch on quickly after that. although i'm sure i'll see another no_doz post related to "WTF is this shit: continuum transfunctioner voltage VS flux capacitor duty cycle VS MAP"...
                          ...thats just the very basics still, but you catch on quickly after that. although i'm sure i'll see another no_doz post related to "WTF is this shit: continuum transfunctioner voltage VS flux capacitor duty cycle VS MAP"...
                          most definitely-and that reminds me! on operation repo there was this like 23 or 24 year old kid who was having his -DELOREAN- repo'd! first off ive probably only seen 1 in my entire life, -maybe- 2, & this kid flips out & goes michael jackson like a MOFO.
                          if you're looking for entertainment i definitely recommend going to hulu & looking up operation repo, and watch "just beat it", i almost cried laughing
                            2 6" stickers, 12" sticker, 2 pens, and 2 note pads I wait till i need to order $100 worth of stuff if I can
                              lol that makes me feel a LOT better-im going to get the burn2 & the $10 attachment so i can read memcals without tearing them apart-idk if that means i can burn them without tearing them apart-it would certainly be nice!!
                              i really appreciate all of your guys help, asylum you alone have saved me $200 and a lot of time saving up the $300 & explaining to my gf why im dumping more money into a vehicle lol
