has anyone used this? i only saw it mentioned once in a search on here. it sounds promising. it edits the bin file and since tunerpro uses bins, im thinking it will work. what do you think?
VEmaster
VEmaster
ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)Tags: None
oh... FuelTrim works fine with it. since wifey's GP runs on $88, the lowest section of the VE table is 20kPa, occasionally, when it sucks enough vacuum to get under it, FT ignores it(and it states that it ignores it), and deals with numbers that are applicable. i've now got the idle BLMs of the GP around 124, but i seem to have hit a roadblock since the VE at that area is like .7 after taking enough VE out, and now i have to take fuel out of the VE adder table. so now i have to retune that main and idle VE table again...
i loaded a bin up into vemaster and it processed it. ill load it up later this afternoon and see how it goes.ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
where do i download this FuelTrim?ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
I would also like to know where you acquire this program you speak of.
VE is still the one thing I have not tuned on my car and I think I would benefit from doing so.
Ok appears to be a OBDI thing... I'll stick with the table modifier program I have.
