Ok my tune is getting pretty close now, between 126-130 BLMs in almost all situations. My INT is pretty close too, with a couple small exceptions.
My question is, for high load situations (60+ kpa) how do you tell when you need more VE versus having more AE? Same goes for decel tuning, how do you know you need lower VE rather then having more DE?
I think the proper way to tune high load VE would be going up a rather large hill so you can get those high load situations without getting into the AE too much, but I don't have any good hills near me that would suffice. Is there any other way? In a small car like mine, I have to give it good throttle to hit 70 kpa so it kicks in the AE quite a bit.
Same goes for DE, do you go down a long hill and cruise at 20-25 kpa to get those low load situations without hitting DE?
Also, what kind of INT values are you guys seeing when your DE kicks in? Under hard decel my INT goes to about 140-145 and hangs there until I change gears or touch the throttle. I'm not entirely sure what I should be seeing there, but I think that's pretty good. Of course, this is only for tuning, because I normally have DFCO enabled. My main concern is the AE tuning at this point.
