Hello;
I was suggested to come here for the information I need.
I run a drivetrian that uses a 27c256 eprom.
I know of other people in my community who area able to successfully burn an erased 27c256.... I seem to be having issues.
Backround;
Currently using Moates Flash & Burn as well as TunerPro RT.
I have a Moates APU1 (all in one).
I use an HDR1 to read/capture stock bin files, and (at least in theory) burn to the erased (still assembled) GM memcal.
I have access to a chip eraser, and already have several cleared.
F&B says that the chip type 27c256 is "read only" - I had presumed that this simply meant that I could not electronnicly erase it (which I know isn't possible with this chip type btw).
I changed to another chip type (can't off hand recall which one it was), and changed the hex addresses to match the original parameters for the 27c256 (000000 & 007FFF?? or something)
I was able to burn - but upon reading the chip, it's quite obvious that it didn't work properly;
The speed limiter/fuel cut out was correct (but that mght have been by sheer chance because I maxed it out), but the rev limit and others were seriously bunked.
Does anyone have a go-around??
Mabey I need to select a specific chip type and change the hex addresses to something completely differentand to "fool" my APU1 into burning my chip(s) correctly??
BTW;
The guy who was supposed to be helping me out on this hasn't even had the courtesy to email me in several months (but he has been online!?)...
I guess good deeds do in fact go unpaid.
I've helped out this guy ALOT already, and he has financially benifited from my help.
Please someone chime in - I know that several 60degree V6 cars came with 27c256 chips (confirmed this on the tunercat site before comming here).
Jonathan
Backround;
BTW;
Jonathan
