Hi everyone,
In my 1991 GP 3.4 dohc my ECM code is a AXSJ and I have Bens chip installed, which I am very happy with but I have done extensive mods to the engine and I purchased a Ostrich 2.0 and tuner pro, EEC Editor, flash & burn, etc.
I have questions...........
First, Do I need the AXSJ Bin File to upload to the Osrich 2.0 or can I use a different compatible code like BHAK for eg.
Second, IF I'm tuning MY ECM will I still be able to use Ben's chip too, or not? OR do I first have to add all his changes to my ECM and then work from there to add or change different area's that I now need to change.
I'm still trying to learn all I can here before I hook up the ostrich to my ECM so I don't screw something up.
Thank you very much in advance for all that are experienced with this.
Regards,
David
Regards,
David
