Well here it is... $A1 Full Ver 0.5.xdf
I put in some more time this morning, I'm about 30% done the constants now.
I'm sure there's a few errors, so if you notice anything wrong, let me know, and I'll fix it for the complete Version 1.0.
Just a couple notes, I'm trying to get everything under it's proper category, this makes things much easier to find.
Also, I put the assembly item name, and what everything does (as copied from 727_730_A1.doc), in the description field. This is so you can use the Item Finder and search using the Description if you have to. This might help if you can't find a certain item, or the title isn't as descriptive as it should be.
