35 lb/hr injectors, adjusted to fuel pressure
Zeitronix WBO2 datalogger
APU 1 emulator
So far I have lowered BPC to about 69.
The 3900 O2 sensor appears to work fine, closed loop status onset is quick.
Problems so far:
Integrator is bottoming out at 76 = rich. Will lower BPC more and adj idle VE
3900 alternator; 13v drops off to 12ish after a short time, suspect little 5v regulator is fading, it's currently connected to terminal "L". Will look into a stronger regulator since the voltage change is affecting idle stability.
I will disable closed loop to use the wideband for idle tuning.
Which crank fuel table should I adjust to avoid starting with clear flood mode?
APU 1 emulator
Problems so far:
