need help tuning please !!!!
  • need help tuning please !!!!
    i can't find a chip for my motor at all it a 88 Z24 with a build hybrid
    and ever body i ask to make me a chip sayz that they need the car to do it right and nobody local does that stuff
    i know nothing about that stuff at all but i am willing to get the stuff to tune it myself if somebody can walk me through it
    what will i be needing and where can i get it ?
    thanks guys
    Try this site, http://www.gmtuners.com/ Darthfiero does a lot of tuning in absentia and maybe able to help you out but you will need to be able to provide him with datalogs to see where your current tune stands. you'll need an ALDL cable and a program for that.
    You can try http://www.tunercat.com/tnr_desc/do_tc.html
    check out supported vehicles and hardware/software sections and Links for tuning equipment. I recommend the Zeitronix wideband O2 datalogger as a start. Usually you can get it new cheaper on Ebay than from their site (not t-cat)
      www.v6z24.com has a lot of guys that could probably burn you a chip ready to go since a lot of them do full 3400 swaps. Or at least send you some code to start off of? You basically have a 2000+ 3100 made.
        well my motor is a 3.1/3400 and here is the basic info
        -h562cp75 speed pro pistons
        -crower cam 290*/298* .470/.492
        -62mm throttlebody
        -accel 21 pound injectors
        -nx wet system with a 125 shot
        -headers
        -msd ignition box
          the auto tranny is the tricky part since most people switch to a 5 speed.
          Your best bet is to pick up an Ostrich emulator, that way you can try to learn the tuning yourself. This site has the bin files for some automatic trannies, I bet one of us could make some quick changes to one of those to get you started.
          as for someone burning you a chip, it's just too time consuming to keep burning chips and sending them through the mail. It only takes a few minutes to send a bin file back and forth.
            The Ostrich emulator has been discontinued and some times they are a bit of a challenge to get working properly. As a beginner you need something that is highly likely to function as described without a fuss to add to your woes which is why I suggested the Zeitronix unit since when connected it immediately indicated an extreme rich condition with my tune. There is another emulator available through another company aside from Moates which is also linked to in the tunercat forum I think the emulator is called the Romulator. You may want to read up on it as well.
            Since you mentioned nitrous I wouldn't dare take a chance with a long distance tune mixed with it.
              what would the auto trans make diffrent ? mine is not computer controled and i dont even have the lock-up hooked
              and what do you mean joe about a londg distance tune ?
              so bacisly all i need is a emulator and a lap top then ?or is there more ?
                Just that, long distance tune, someone out of town burning a chip for an engine combination they have never seen or sat behind. A stock 3 speed with the lockup converter disabled is probably not going to last long behind a power increase. By not having the transmission lockup active it's going to run hotter.
                  The newest breed of emulator has evolved! This is the newest Ostrich, the 2.0 unit. It is extremely small and compact, durable, versatile, and powerful. Full 921.6k speed, from 4k (2732A) up to 512k (4mbit 29F040) and everything in between (27C128, 27C256, 27C512).
                  Ostrich 2.0
                  that's what i use, it works great.
                  there are still constants in the computer for the auto tranny, the TCC, VSS, different idle settings and some other random things.
                    http://www.moates.net/product_info.p...roducts_id=169
                    Ostrich 2.0
                    Look at the last typed line at the bottom of the page above the red border line.
                    Moates.Net : Welcome to www.moates.net! - Chips and Sockets RMA: Repairs & Returns Software List All Products (150+) Cables USB/Emulation/PC Shop by Vehicle WideBand Products Ford 1986-2004 GM 1985-1995 Nissan 1986-1995 Honda/Acura 1988-1995 Driver Download Browse Products Datalog and Reflash Realtime Emulation Chip Programming
                      so if my car was a original 5spd car i would need a new ecm then ?
                      i have like 4 of them so if i have to change it thats no big problem
                      or would it be easyer to get a aftermarket ecu or would that be the same trouble ?
                        looks like that's for the original Ostrich, the 2.0 page dosen't say anything. I even added one to my cart just fine...
                          the ECM's are the same, the chip in them is different...
                          you should read this sticky over on V6Z24.com...
                            hey dave it says there that you have to sawp out to a 92-94 chip but don't they have cut off in them ?
                            i know a buddy of mine changed a 94 ecu to a 90 to get rid of the cut off and his car did not run right ? was that somthing he did wrong or ?
