i know this isnt really a tuning question, but i guess this is where it goes...
so, my car has been having this sputtering problem for a while just off idle till about 2000 RPM or so, so i tested the fuel pressure...good, the ignition system is good (new plugs, wires, coils ohm test good, icm bench tested good), etc. i tested the TPS voltage today and it was below spec in all areas.
so, i replaced it w/ a delco unit and the all hell broke loose. the car wont idle for shit and it bogs down when you give it too much gas. i did an idle relearn (actually about 3 or 4 total) and also replaced the iac and map for the hell of it. same thing. then, i put the old tps back in and same thing. i also got a code 22 (tps) and 34 (map). both are reading 0 volts now and both test charts led me to a bad ecm or wire, so its gotta be the ecm, right? there are a couple other codes, but nothing that serious (23, 35). i also did the tap test for loose solder joints on the prom and no change.
a little more history: i didnt do any tests, but it seemed like in the past when i would unhook the battery for a long time to do some repairs (im talking days to weeks), it would run fine for a while and then start acting up again, recently it has been the worst. the night my belt shredded, after i got a new one on, it was acting up after it had been fine up until that point. it also got better right away after i replaced the wires, but it was still acting up some, just not as bad.
so, do you think bad ecm? i cant think of anything else that would case both the MAP and the TPS to read 0 V. btw, it does have one of those possibly illegal FFP chips made by ben w/ EGR and AIR delete, stock shift points (7K)
