A friend of mine has a 91 Olds 98, that's having a weird problem. It has the full digital/LCD dash; the problem is that after driving for a few minutes, it shows the battery voltage to be out of spec, something like 16v or something like that. I put my meter in parallel with the batter at idle and the voltage is actually ~14v; so it's fine. My question is, does this vehicle have a sub controller for the dash or does the ECU control everything? Lastly is there anyway to put this vehicle into diagnostics like you can with Cadillacs? Thanks, ya'll are the best!
Regards,
Tee
Regards,
Tee
